removing old cat back from cat
Old Sep 25, 2006 | 02:48 PM
wudini's Avatar
Default removing old cat back from cat
i need to get the custom bent cat back exhaust off of my old eg coupe for use on my new ek coupe. however the 3 bolts holding the cat back to the cat are pretty damn rusted. (bolted flush, not spring/bolt). anyone have any tricks to breaking the bolts free/off? maybe heat? i cant start the car to heat up the bolts, so i'd have to use a torch.
also, the exhaust is one piece, i can't take it apart at all, this shouldnt be a problem in getting it off should it? i assumed i could just jack up the rear end and slip it over the suspension.
Old Sep 25, 2006 | 02:53 PM
knockout's Avatar
Default Re: removing old cat back from cat (wudini)
just use brute strength. heat makes metal expand so it'll just make it harder so youre better off just maybe spraying wd-40 on the bolts and puting some muscle into it. make sure youre straight on the nut with the wrench so you dont strip anything.
Old Sep 25, 2006 | 02:55 PM
Miracle's Avatar
Default Re: removing old cat back from cat (knockout)
Works every time, and 100x better than WD-40.
Old Sep 25, 2006 | 03:00 PM
knockout's Avatar
Default Re: removing old cat back from cat (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">
Works every time, and 100x better than WD-40.</TD></TR></TABLE>
totally forgot about that stuff.
to the OP:
get your hands on that, i think ive seen similar products (if not, the same exact product) at most any autoparts/hardware store
Old Sep 25, 2006 | 03:01 PM
wudini's Avatar
actually i dont know about heat making it harder...have you ever tried to take headers off of a cold engine? its almost impossible. then again the head is aluminum and the bolt is steel.
Modified by wudini at 8:14 PM 9/25/2006
Old Sep 25, 2006 | 03:02 PM
wudini's Avatar
yea i have a can of PB...totally forgot about it.
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">
It is some good stuff. I used to to free up the rusted OEM downpipe on my GS-T when I had it, and it has always been good around the house as a lubricant, and doing mechanical work.
t0kyoStatus
Jan 23, 2009 10:41 PM
intgraCA
May 23, 2007 04:43 PM
fw190bvi
Apr 25, 2005 04:09 PM
dip-set
Nov 21, 2003 08:04 AM
JeremyL
Dec 16, 2002 04:41 PM
