valve clearance ?
Old Sep 25, 2006 | 02:45 PM
vtec-gorilla's Avatar
Default valve clearance ?
i got a fully built skunk 2 head with skunk2 pro 2 in it, with a jdm gsr block know if i install a set of p30 pistions will i have enough valve clearance? cause i keep hearing i wouldn't this setup will never work.
Old Sep 25, 2006 | 02:49 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: valve clearance ? (vtec-gorilla)
will work if cams are degreed in (exuse the spelling)
Old Sep 25, 2006 | 03:29 PM
Default Re: valve clearance ? (WHITFIELD-TUNED)
so it would be safe to use with a comp ratio of 11.8.1
Old Sep 25, 2006 | 04:02 PM
DonF's Avatar
At a 102 IN ctr. line and 106 EX centerline youu should be fine.
Old Sep 25, 2006 | 08:09 PM
DYNO-PRO
Default Re: valve clearance ? (DonF)
donfs NEW name "MR TECHNICAL" i love it ... now can you write a paragraph explaining to this poor soul how to actually go about dialing in the lobe centers or maybe just post what the gears should be set at
alcarp
Mar 4, 2010 05:15 PM
Fei
11
Jul 28, 2008 12:21 AM
battle2.0ek9
Feb 26, 2007 04:52 AM
SupaFly_Honda
Oct 15, 2003 04:37 PM
McFly
Mar 2, 2003 08:01 PM
