Feel a rev even when you let off the gas?
I dont know, since i took my FG1 off the lot. whenever i go from first to second, even if i shift on low RPM like 3,000, once i press the clutch and let go of the gas totally, the car makes a reving sound... ? anyone has an idea why? (yes i have tried letting the gas go before pressing the clutch also)
sounds alot like the rev hang probem that the fg2's were having. I had to get it reflashed at the dealer. you should check with the service tech at your local dealer and see if there is an update for your car.
Maybe the FG1 R18's have the same problem with the rev hang as the K20Z3 Si's.
the R18 has a DBW system, so I could see why it would have the same problems.
Modified by .Red.EM2 at 5:49 PM 9/25/2006
Could this be the jump i get after shifting gears sometimes? Sometimes, about a full second after letting the clutch out and hitting the gas, i feel a sudden surge.
I told a guy at the dealer... he said "it's probably just the VTEC" I never wanted to slam someones face into their desk as much as i did at that moment.
i dont know if my FG auto is same , but when i press on gas ( when ever parked) on low rpm range and let it go all sudden it goes like hangs then vrooom all sudden.... mb if i do a video will it help explain things better?
Aphelion
Aug 6, 2005 11:17 PM
tallblondkid
Sep 15, 2004 01:24 PM
nY's FiNeSt
26
Oct 3, 2003 05:30 AM
