Master cylinders
Old May 1, 2002 | 04:16 AM
olddriver's Avatar
New User
Default Master cylinders
Does anyone know if there is a difference between ABS and regular brake master cylinders. I want to use an ABS MC on my non ABS car. I hoping the larger pump volumn (larger bore) of the ABS unit will compensate (somewhat) for the long pedal and give me a little less pedal travel. The car is a 90 civis hatch (disk rear) - track only.
Old May 1, 2002 | 07:16 AM
Doctor CorteZ's Avatar
Default Re: Master cylinders (olddriver)
usually you just have to move the lines a little
ie: bend or whatever , get a non abs one from a 90-97 integra
should just drop in, 15/16th's bore i believe
richcon
Jun 10, 2007 07:50 AM
Chim Chim
Mar 31, 2007 07:36 AM
