Steering/Suspension Problem?
Recently I put my 17's back on for the summer and I had them rebalanced. In a straight line every thing is fine, when I make a hard left turns or high speed left turns the steering wheel shakes liked warped brake rotors. It never did this before in the same conditions, (corner and current wheels). I have Ground Control and stock struts (for now). What could be the problem. Only on left turns and only if there is a strong load on the suspension. No problems if I'm driving slow or straight. Only on hard corners. Help? I'm worried
My guess: Motor mount
CV Joint
Wheel Bearing
Just need struts that bad? ?
[Modified by Si4WS, 5:02 AM 5/1/2002]
CV Joint
Wheel Bearing
