help!!!! dripping oil out of flywheel cover
Old Sep 24, 2006 | 07:23 PM
gsxr1k05's Avatar
Default help!!!! dripping oil out of flywheel cover
i did the auto to man swap, and i leak oil out of the flywheel cover. is there supposed to be a gaskey or something that goes between the trans and the cover? there wasnt one when i took it from the junkyard. or is it the trans got over filled?? i just put 2 quarts into it in the inspection hole until it ran out like the manual said. any ideas??
Old Sep 24, 2006 | 07:27 PM
Lil Red CRXsi's Avatar
Default Re: help!!!! dripping oil out of flywheel cover (gsxr1k05)
rear main seal?
Old Sep 24, 2006 | 07:28 PM
gsxr1k05's Avatar
Default Re: help!!!! dripping oil out of flywheel cover (Lil Red CRXsi)
i dont think so, cause it did not start doing this till i did the swap.
Old Sep 24, 2006 | 07:47 PM
91SiZ6's Avatar
That's the only thing it could be if it's actually leaking from the flywheel cover. There's nothing else in the bell housing of the transmission that would leak. Other possibilities are one of the axles not being fully seated or you may have overfilled the transmission and caused it to weep from the fill bolt.
Old Sep 24, 2006 | 09:05 PM
gsxr1k05's Avatar
how could the rear main have gone while doing this swap?? it only leaks when the engine it running.
Old Sep 24, 2006 | 09:50 PM
gsxr1k05's Avatar
assuming it is a rear main seal, how hard is it to change. and is there a write up for it??
Old Sep 24, 2006 | 11:38 PM
civickiller's Avatar
Default Re: (gsxr1k05)
input shaft seal?
Old Sep 25, 2006 | 05:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">how could the rear main have gone while doing this swap?? it only leaks when the engine it running.</TD></TR></TABLE>
things happen when you do changes on an old car.The rear main will only leak while the motor is running.
Old Sep 25, 2006 | 05:18 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">assuming it is a rear main seal, how hard is it to change. and is there a write up for it??</TD></TR></TABLE>
It's not hard...it's more or less a pain in the ***. Tranny needs to come off, oil pan needs to come off. Honestly, I'd look at the seals above the tranny before going into the tranny. My seal to block of a manual fuel pump cracked and was pissing so much oil on my clutch that it oil soaked it.
dads95ss
Jul 14, 2012 07:45 PM
J tech
Nov 10, 2010 06:09 AM
gsxr1k05
14
Oct 12, 2006 05:05 AM
crzyfool24
18
Jun 6, 2005 07:54 PM
kspeed
Apr 26, 2004 11:00 AM
