turbo peformance manifold?
Old Sep 24, 2006 | 12:54 PM
eVo05's Avatar
Default turbo peformance manifold?
i have a turbo performance manifold, wastegate goes upward angle, i have a 4 psi spring in it, but it will boost to almost 11-12 psi with no controller. Can anybody help me to why this is happening?
Old Sep 24, 2006 | 01:05 PM
siblues's Avatar
Default Re: turbo peformance manifold? (eVo05)
You are most likeley having problems with the wastegate pklacement on the manifold?You should post a pic of the manifold and some more info on your setup
Old Sep 24, 2006 | 01:17 PM
eVo05's Avatar
Default Re: turbo peformance manifold? (siblues)
http://www.turbo-performance.com
b series manifold
wastegate placement comes off the right side looking at the motor.
wastegate tial 38mm 4psi spring.
garret t3/t4 turbo
im going to try to port the wastegate opening as much as i can....
im also running open downpipe, and i think that is causing it as well.
any other info would be greatly apprieciated.
Old Sep 24, 2006 | 01:20 PM
siblues's Avatar
I had the same problem with my drag and open downpipe .I think it is a combination of both but the downpipe is the major problem.
Old Sep 24, 2006 | 05:10 PM
eVo05's Avatar
yeah? Im hoping its the downpipe and a combo...and nothing serious.....i'll let you know tomorrow i just bought a dremel and im going to port out the wastegate as much as i can
Old Sep 25, 2006 | 07:47 PM
eVo05's Avatar
well i ported the manifold and it drastically reduced the problem, and its livable now so im good! thanks man
Old Sep 25, 2006 | 08:06 PM
siblues's Avatar
Sounds good man good luck with it
wtsapexipowerfc
May 29, 2010 07:58 AM
starcrossed010
Mar 4, 2007 01:00 PM
Meet07
Mar 28, 2006 07:23 AM
dtec
Aug 10, 2003 02:25 PM
2.2
Sep 17, 2002 07:13 AM
