Fastbrakes 11.75 four piston kit
Old Sep 24, 2006 | 10:07 AM
Dr Pooface's Avatar
Default Fastbrakes 11.75 four piston kit
Anyone use this kit? I need more stopping power, but want to retain my 15" wheels (kosei k1's).
http://fastbrakes.com/shop/pro...d=418
Old Sep 24, 2006 | 10:50 AM
88 rex's Avatar
Default Re: Fastbrakes 11.75 four piston kit (Dr Pooface)
Wow, $1300 for 3/4 of an inch in rotor and bigger calipers. Why not just get some NSX/Legend calipers and some really good pads? That would be A LOT cheaper.
Just wondering why you think your brakes are inadequate? ITR brakes are known to be track worthy.
Old Sep 24, 2006 | 11:12 AM
1GreyTeg's Avatar
Default Re: Fastbrakes 11.75 four piston kit (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Wow, $1300 for 3/4 of an inch in rotor and bigger calipers. Why not just get some NSX/Legend calipers and some really good pads? That would be A LOT cheaper.</TD></TR></TABLE>
I don't think the price is too bad considering the price of Spoon calipers that don't increase the rotor size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering why you think your brakes are inadequate? ITR brakes are known to be track worthy.</TD></TR></TABLE>
But his car is Turbo and I'm sure he's going alot quicker than many of us and more than likely beating on the brakes to the point of red headed stepchild abuse.
Old Sep 24, 2006 | 11:18 AM
LunchboxZT's Avatar
Default Re: Fastbrakes 11.75 four piston kit (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
But his car is Turbo and I'm sure he's going alot quicker than many of us and more than likely beating on the brakes to the point of red headed stepchild abuse.</TD></TR></TABLE>
Haha..
But yeah, NSX cal's + legend rotors ftw
Old Sep 24, 2006 | 11:49 AM
Dr Pooface's Avatar
Default Re: Fastbrakes 11.75 four piston kit (LunchboxZT)
My car makes 325hp. My corner enterance speed is considerably faster than most ITR's, I'm tired of having to let off early and deal with brake fade. I'm also not convinced the NSX upgrade will be good enough.
I'm just trying to find the best set up that will resist fade but still allow me to retain my 15" wheels. Any one with some actual experience with this fastbrake kit?
Old Sep 24, 2006 | 12:28 PM
Chris F's Avatar
I have it on the 'lude. It kills the OEM R brakes in terms of longevity and fade. Plus it's a ton lighter than OEM brakes.(yes, a ton. 2000 lbs).
Feel is really good too, but the 'lude has no ABS and a manual proportioning valve for front/rear.
Kosei K1 +38mm clears fine, but it's awfully close (i.e. the wheel has scrapes on it from when the wheel bearing went bad and made gentle contact with the caliper). If you have +43 or so wheels you might need spacers.
Old Sep 24, 2006 | 12:31 PM
1GreyTeg's Avatar
Default Re: Fastbrakes 11.75 four piston kit (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I have it on the 'lude. It kills the OEM R brakes in terms of longevity and fade. Plus it's a ton lighter than OEM brakes.(yes, a ton. 2000 lbs).
Good info Chris
BTW I wanted to know what you go through more, motors or wheel bearings?
Old Sep 24, 2006 | 04:22 PM
94rs-turbo's Avatar
yeah depends on the wheels but those will clear 15's but i just dont like wilwood
Old Sep 24, 2006 | 04:25 PM
white rocket's Avatar
What pads can be used with the Wilwood klappers? Actually, let me rephrase that;
CAN YOU USE COBALT FRICTION PADS WITH THE WILWOOD KLAPPERS?. There, that's better
Old Sep 24, 2006 | 04:31 PM
Dr Pooface's Avatar
Default Re: (white rocket)
Chris F: Great info, thanks. I think this is the route I'm gona go.
WR: Info from fastbrakes re: Wilwood pads: http://fastbrakes.com/shop/index.php?cPath=22_178
Old Sep 24, 2006 | 04:37 PM
Default Re: (Dr Pooface)
Touche!! I guess reading pwns me .
They only list the GT-Sport pads. I wonder if any of the other compounds are adaptable?
Old Sep 24, 2006 | 05:09 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I have it on the 'lude. It kills the OEM R brakes in terms of longevity and fade. </TD></TR></TABLE>
Which pads are you using?
Old Sep 25, 2006 | 04:28 AM
Chris F's Avatar
Ferodo DS3000
ImPuLsIvE
Aug 31, 2006 04:10 PM
95greenteg
Jul 19, 2005 08:58 AM
555R
10
Nov 30, 2004 04:38 PM
murena
Oct 9, 2004 12:52 AM
Nuts
Aug 1, 2003 09:02 AM
