rear brake squeak
Old Sep 24, 2006 | 09:25 AM
BLUE EH3's Avatar
Help we my pennies
Default rear brake squeak
my rears squeak when i let OFF the brake... why?
Old Sep 24, 2006 | 10:07 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: rear brake squeak (BLUE EH3)
bump
Old Sep 24, 2006 | 11:52 AM
BLUE EH3's Avatar
Help we my pennies
bmp
Old Sep 24, 2006 | 12:18 PM
Miracle's Avatar
That means either the wheel bearings are going out (likely) Or the wheel cylinder is not pulling the shoes all the way off of the drum lining. Check to make sure everything is adjusted properly, and cleaned.
Old Sep 24, 2006 | 12:25 PM
mugenpowered's Avatar
That's weird, someone just posted the same question about the same car on another forum that I frequent. But considering you are from NJ I guess it isn't you.
People said to grease your sliders & put some brake-quiet on the pads. I dunno if that will work but just passing the info. along.
Old Sep 24, 2006 | 03:10 PM
Miracle's Avatar
Default Re: rear brake squeak (mugenpowered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenpowered &raquo;</TD></TR><TR><TD CLASS="quote">People said to grease your sliders & put some brake-quiet on the pads. I dunno if that will work but just passing the info. along.
That is for the front. I don't THINK he had rear rotors, but I may be wrong. But you are right any way it goes.
Old Sep 25, 2006 | 03:40 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: rear brake squeak (.Red.EM2)
i got ek drums
Old Sep 25, 2006 | 03:48 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">i got ek drums</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">That means either the wheel bearings are going out (likely) Or the wheel cylinder is not pulling the shoes all the way off of the drum lining. Check to make sure everything is adjusted properly, and cleaned.</TD></TR></TABLE>
Old Sep 25, 2006 | 04:26 AM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">That means either the wheel bearings are going out (likely) Or the wheel cylinder is not pulling the shoes all the way off of the drum lining. Check to make sure everything is adjusted properly, and cleaned.</TD></TR></TABLE> so i should take off the drum and spray brake cleaner
Old Sep 25, 2006 | 04:34 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote"> so i should take off the drum and spray brake cleaner</TD></TR></TABLE>
That, and make sure everything is adjusted properly. When it is done right, you should be able to put the drum on, and it should spin freely with the E-Brake disengaged.
Old Sep 25, 2006 | 05:05 AM
ZacCarter's Avatar
I seriously doubt it is the wheel bearing, honda uses cartridge style bearings which seldomly have to be replaced unless they have well over 200k miles or there are extreme conditions, check to make sure everything is adjusted properly.
Old Sep 25, 2006 | 05:22 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (ZacCarter)
i dont wantasound dumb but what do u mean adjusted? wat part shouldbe checked
Old Sep 25, 2006 | 05:23 AM
BLUE EH3's Avatar
Help we my pennies
That, and make sure everything is adjusted properly. When it is done right, you should be able to put the drum on, and it should spin freely with the E-Brake disengaged.</TD></TR></TABLE> will do 2morrow
Old Sep 25, 2006 | 05:26 AM
ZacCarter's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">i dont wantasound dumb but what do u mean adjusted? wat part shouldbe checked</TD></TR></TABLE> There are a couple springs and a star adjuster, there may just be some dirt in there, just spray it out with brake cleaner.
Old Sep 25, 2006 | 09:06 AM
BLUE EH3's Avatar
Help we my pennies
yea , i when to the shop and they dont the springs ad etc needed to geased/cleaned up
hamadiscool
Jun 19, 2006 01:35 AM
EG2Driver
Jun 18, 2006 12:45 PM
96Civic_Coupe
23
Aug 22, 2005 10:57 PM
MechEng
May 10, 2004 05:12 AM
cccya
Oct 25, 2002 06:06 PM
