rear brake squeak
Re: rear brake squeak (BLUE EH3)
That means either the wheel bearings are going out (likely) Or the wheel cylinder is not pulling the shoes all the way off of the drum lining. Check to make sure everything is adjusted properly, and cleaned.
That's weird, someone just posted the same question about the same car on another forum that I frequent. But considering you are from NJ I guess it isn't you.
People said to grease your sliders & put some brake-quiet on the pads. I dunno if that will work but just passing the info. along.
Re: rear brake squeak (mugenpowered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenpowered »</TD></TR><TR><TD CLASS="quote">People said to grease your sliders & put some brake-quiet on the pads. I dunno if that will work but just passing the info. along.
That is for the front. I don't THINK he had rear rotors, but I may be wrong. But you are right any way it goes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">i got ek drums</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">That means either the wheel bearings are going out (likely) Or the wheel cylinder is not pulling the shoes all the way off of the drum lining. Check to make sure everything is adjusted properly, and cleaned.</TD></TR></TABLE>
Help we my pennies
Re: rear brake squeak (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">That means either the wheel bearings are going out (likely) Or the wheel cylinder is not pulling the shoes all the way off of the drum lining. Check to make sure everything is adjusted properly, and cleaned.</TD></TR></TABLE> so i should take off the drum and spray brake cleaner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote"> so i should take off the drum and spray brake cleaner</TD></TR></TABLE>
That, and make sure everything is adjusted properly. When it is done right, you should be able to put the drum on, and it should spin freely with the E-Brake disengaged.
I seriously doubt it is the wheel bearing, honda uses cartridge style bearings which seldomly have to be replaced unless they have well over 200k miles or there are extreme conditions, check to make sure everything is adjusted properly.
Help we my pennies
That, and make sure everything is adjusted properly. When it is done right, you should be able to put the drum on, and it should spin freely with the E-Brake disengaged.</TD></TR></TABLE> will do 2morrow
Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">i dont wantasound dumb but what do u mean adjusted? wat part shouldbe checked</TD></TR></TABLE> There are a couple springs and a star adjuster, there may just be some dirt in there, just spray it out with brake cleaner.
cccya
10-25-2002 06:06 PM
