89 civic 4 dr lx dpfi help with ecu
There is an LED window on the ECU. it will blink a code when the car is on or started.
http://www.c-speedracing.com/faq/05.php
so........just lift the carpet under pass floor w/ key on and count lights. even thow the dash check light is off....... am i right? i hate this ecu y cant i hook up a $1000 comp link from school to read codes and run spec test on all sensors. sorry had to ramble
yeah turn the key to the on position and look at the red light on the ecu...1 short blink = 1,,1 long blink = 10...so for example 3 short blinks is code 3...1 long and 2 short is code 12..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">yeah turn the key to the on position and look at the red light on the ecu...1 short blink = 1,,1 long blink = 10...so for example 3 short blinks is code 3...1 long and 2 short is code 12..</TD></TR></TABLE>
i think that's a diff. gen.
Mine just reads a bunch of short blinks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicaz »</TD></TR><TR><TD CLASS="quote">ok just went out and turnd key till radio turned on and no blinks.................. so now what?</TD></TR></TABLE>
Your codes were most likely cleared at one point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch »</TD></TR><TR><TD CLASS="quote">You have to go to the next position on the key where the fuel pump clicks on
ya, that. hehe, i just figured...
</TD></TR></TABLE>ya, that. hehe, i just figured...
thats wrong^^ might be right for other ecus but a stock 91 ecu its all just short blinks. if you have no codes then your all good.. why do you want to know what codes you used to have?
civicracer94
Dec 8, 2006 06:22 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
