need to know size of stock h22 exhaust pipe?
Old Sep 23, 2006 | 02:38 PM
oneforce's Avatar
Default need to know size of stock h22 exhaust pipe?
I need to know what size a stock 93 h22a piping is?Thanks
Old Sep 23, 2006 | 03:05 PM
hamadiscool's Avatar
Default Re: need to know size of stock h22 exhaust pipe? (oneforce)
if u r asking for the diameter then i am pretty sure its 2 inches.
Old Sep 24, 2006 | 04:24 PM
oneforce's Avatar
Default Re: need to know size of stock h22 exhaust pipe? (hamadiscool)
thanks
my friend is planning on buying an ebay cat and it says that the cat is a direct fit, but its 2.5 inch piping? idunno, sounds kinda fishy to me.. thanks though
Old Sep 25, 2006 | 03:07 PM
E-Money's Avatar
2 inches
Old Oct 3, 2006 | 12:29 PM
951dc5's Avatar
Default Re: need to know size of stock h22 exhaust pipe? (E-Money)
yeah, anyone would know this? 2.5 into a 2.0 diameter.
Old Oct 5, 2006 | 09:41 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: need to know size of stock h22 exhaust pipe? (Prelude951)
you can make it work by hacking off the flanged ends....but the effect of going from 2 in into 2.5 back out to 2 inch isnt ideal...personally i would try to find a 2 in cat OR just drop the cash to upgrade the whole system to 2.5....your call either way, but finding a 2in cat is easier/cheaper
Old Oct 5, 2006 | 11:09 AM
951dc5's Avatar
Default Re: need to know size of stock h22 exhaust pipe? (GRAF-FITI)
thanks for your advice. i agree. stock 2.0 into 2.5 wouldnt be get a good flow correct?
Old Oct 5, 2006 | 12:00 PM
GRAF-FITI's Avatar
* B A N N E D *
it wouldnt be horrible but it would probably mess up your back pressure a little, which is what exhaust is all about...stick w/ the 2 in and you'll be fine...but if you're obd2 make sure you get one with the bung welded in so you can just plug in your oxygen sensor without having to buy a new bung, cut a hole, and weld it in
Old Oct 5, 2006 | 01:11 PM
951dc5's Avatar
i don't know if i'm OBD2. My year prelude is 1993. i think's its obd1 correct?
I just ordered a carsound megaflow cat 2.0 diameter. is there anything i should know when taking it to weld shop? Thank you again
Old Oct 5, 2006 | 01:23 PM
GRAF-FITI's Avatar
* B A N N E D *
yes you are obd1....there for yuo should only have 1 o2 sensor....so just have em weld it up and you'll be good to go
Old Oct 5, 2006 | 04:02 PM
951dc5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">yes you are obd1....there for yuo should only have 1 o2 sensor....so just have em weld it up and you'll be good to go</TD></TR></TABLE>
did you mean have them weld the o2 sensor on the cat? hopefully it's not what u meant.
Employee24
10
Apr 10, 2008 04:52 AM
mr devious illusions
Jun 5, 2006 05:55 PM
1998teg
Aug 20, 2004 09:06 AM
JDMvtecDRAGSTA
Jan 22, 2003 05:16 PM
J.R.
Aug 16, 2002 08:19 PM
