Could this be true about Anti-Seize?? If so, no more for me.
I was surfing the net and I came across this:
Install each plug into the cylinder heads without using any anti-seize compound. Torque the spark plugs to 25 Nm (18.4 ft-lbs). While writing "How to Rebuild and Modify Porsche 911 Engines", I discovered that Porsche doesn’t recommend the use of anti-seize compound, as detailed in Porsche Technical Bulletin 9102, Group 2, identifier 2870. The bulletin applies retroactively to all Porsche models and the theory is that the anti-seize tends to act as an electrical insulator between the plug and the cylinder head. This could have detrimental effect on the firing of the spark due to the loss of a good, consistent ground connection. Keeping those findings in mind, I would make the same recommendations for the BMW cars.
Here is the link for the entire article:
http://www.pelicanparts.com/bm....htm
TravisBiggie
Sep 29, 2013 06:33 PM
e_r_i_c_
Sep 20, 2003 08:01 PM
auto_destroyer
Aug 10, 2002 08:36 PM
