Help Help water mixing with oil ????
Old Sep 23, 2006 | 10:32 AM
eg4life1202's Avatar
Default Help Help water mixing with oil ????
i just put on a gsr head on to my b16b block and when i fill up the radiator water comes out of my oil pan with the drain plug off
what did i do wrong with the block swap /???
please help
the block is a JDM b16b and the head is a usdm GSR
could i have hooked up some hoses wrong ???
i noticed the the jdm block has a oil filter cooller and my usdm gsr block does not
would that make any difference??
Old Sep 23, 2006 | 10:39 AM
Brick Top's Avatar
sounds like you forgot to put the head gasket on. retrace your steps. how did u install the head?
Old Sep 23, 2006 | 10:41 AM
Default Re: Help Help water mixing with oil ???? (eg4life1202)
i fallowed my helms manuel
i tried filling the water in through the filler neck on the head with a hose and it goes straight out the oil pan
andypwnz
Feb 19, 2013 03:40 PM
axionm1k
Feb 26, 2008 06:33 AM
axionm1k
Feb 26, 2008 06:10 AM
fastforwardracer
Jul 14, 2007 08:40 AM
bxsi
May 1, 2003 07:33 AM
