B18c upgrade from sohc query
Old Sep 22, 2006 | 04:24 PM
NZDelsoldude's Avatar
Default B18c upgrade from sohc query
Hey guys,
Just wondering what engine mounts I need to use when swaping my sohc d15b for a dohc b18c? Also what will need changing ie fuel pump? I did a search but could only find the b16 to b18 upgrade.
Cheers Greg
Old Sep 22, 2006 | 04:27 PM
YodajdmEK4's Avatar
Default Re: B18c upgrade from sohc query (NZDelsoldude)
I have Hasports and they work pimp, also get a fuel pump!
Old Sep 22, 2006 | 04:33 PM
Luserkid's Avatar
Default Re: B18c upgrade from sohc query (YodajdmEK4)
If your looking for an upgrade then for sure get the Hasport kit, but the stock ones work just fine for throwing the engine in. Stock fuel pump will work fine as well.
Old Sep 22, 2006 | 07:32 PM
Default Re: B18c upgrade from sohc query (Luserkid)
so I use the stock B18c ones?
Old Sep 23, 2006 | 11:38 AM
HATCHY24's Avatar
JUST DID THAT SWAP . USED AVID MOTOR MOUNTS WHICH ARE THE SAME AS HASPORT. ALSO USED WALBRO 255 FUEL PUMP. ALSO RECOMMEND RC 310 FUEL INJECTORS.
Old Sep 23, 2006 | 11:47 AM
UberMunkey's Avatar
Default Re: B18c upgrade from sohc query (HATCHY24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHY24 &raquo;</TD></TR><TR><TD CLASS="quote">JUST DID THAT SWAP . USED AVID MOTOR MOUNTS WHICH ARE THE SAME AS HASPORT. ALSO USED WALBRO 255 FUEL PUMP. ALSO RECOMMEND RC 310 FUEL INJECTORS. </TD></TR></TABLE>
there's no need to upgrade the injectors when swapping in a stock b18c, just use the ones that came with the motor swap. also, the stock fuel pump will work fine unless you plan on turboing it some time soon.
trojan
Sep 17, 2011 01:22 PM
spags930
Sep 27, 2010 09:53 PM
Vtakkk
Feb 22, 2006 07:20 AM
SPOONfdEK
Sep 4, 2003 08:28 AM
blkrice
Nov 11, 2002 03:27 PM
