B18c upgrade from sohc query
Hey guys,
Just wondering what engine mounts I need to use when swaping my sohc d15b for a dohc b18c? Also what will need changing ie fuel pump? I did a search but could only find the b16 to b18 upgrade.
Cheers Greg
Cheers Greg
Re: B18c upgrade from sohc query (YodajdmEK4)
If your looking for an upgrade then for sure get the Hasport kit, but the stock ones work just fine for throwing the engine in. Stock fuel pump will work fine as well.
Re: B18c upgrade from sohc query (HATCHY24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHY24 »</TD></TR><TR><TD CLASS="quote">JUST DID THAT SWAP . USED AVID MOTOR MOUNTS WHICH ARE THE SAME AS HASPORT. ALSO USED WALBRO 255 FUEL PUMP. ALSO RECOMMEND RC 310 FUEL INJECTORS. </TD></TR></TABLE>
there's no need to upgrade the injectors when swapping in a stock b18c, just use the ones that came with the motor swap. also, the stock fuel pump will work fine unless you plan on turboing it some time soon.
spags930
09-27-2010 09:53 PM
