Prothane and Energy engine mounts
Old Apr 30, 2002 | 07:37 PM
mugenintegra16's Avatar
Default Prothane and Energy engine mounts
Has anyone tried to use both of the these kits at the same time what are your opinions?
Old Apr 30, 2002 | 07:38 PM
Casey's Avatar
Default Re: Prothane and Energy engine mounts (mugenintegra16)
which is better for street use also? Ive heard the prothane are very stiff but the energy arent stiff enough thanks
Old Apr 30, 2002 | 08:55 PM
paul_573's Avatar
Default Re: Prothane and Energy engine mounts (TypeRformewhenIB18)
Ask Crunch on this board. He has Prothanes on "his" ITR. He should give you some input.
-Paul
Old May 1, 2002 | 05:40 AM
98TypeR896's Avatar
what are the part #'s for the R's, if anyone knows.
Old May 2, 2002 | 06:49 AM
Black R's Avatar
25 Year Member
fwiw, I purchased the ES kit recently... 6 inserts that go into the 3 lower mounts - they work with the stock mounts.
They don't have anything for the upper mounts - so I figure I'll try to find some upper mounts if they're not stiff enough.....
Old May 2, 2002 | 09:50 AM
PM-Performance's Avatar
Default Re: Prothane and Energy engine mounts (Black R)
i have the es ones to , i just didnt put em in yet ,
i hear they help for wheel hop , but very stiff and get alot of vibration .
Old May 2, 2002 | 10:03 AM
sgT's Avatar
sgT
Default Re: Prothane and Energy engine mounts (itr206)
prothane mounts are so stiff, I can see them ripping the mount right off the car.
They are NOTHING like the ES inserts
Old May 2, 2002 | 10:18 AM
Big Phat R's Avatar
I have the ES ones.
Traction/wheel hop is way better at the expense of some vibration. If you run an aftermarket clutch like I do - prepare for some crazy dashboard vibration.
Old May 2, 2002 | 10:19 AM
Bob#455's Avatar
Default Re: Prothane and Energy engine mounts (Phat Bastard)
What clutch are you using?
Old May 2, 2002 | 10:21 AM
Big Phat R's Avatar
Default Re: Prothane and Energy engine mounts (Bob#455)
Mugen 3-puck
** the vibration is only during clutch engagement in 1st (i.e. chatter)
[Modified by Phat Bastard, 11:23 AM 5/2/2002]
Old May 2, 2002 | 10:39 AM
typer_801's Avatar
Doesn't sound like either of these kits are very comfortable for a street driven car. Are there any other choices short of the $$$$ Spoon and Mugen ones which are $400+ bucks.
Mine are dying and need replaced.....tons of drivetrain slop right now
Old May 2, 2002 | 10:42 AM
sgT's Avatar
sgT
Default Re: Prothane and Energy engine mounts (typer_801)
spoon/mugen mounts dont do ANYTHING.
If your mnounts need replacing, the ES inserts wont do anything either
hawkturbo
Nov 17, 2008 02:11 PM
white_db8
May 26, 2007 09:34 AM
CA6VTEC
Oct 18, 2005 09:33 PM
Drew Peacock
Dec 3, 2004 03:31 PM
vtecmike1
Nov 19, 2003 07:19 AM
