anybody have problems chipping a p28 automatic?
Yes I have a problem. I have chipped 4 p28's before with no problem. This one is a virgin p28 auto. When done it would not run from the code on the chip, it would just run on the stock map. The 550 injectors didnt like that. I dont know whats wrong with the ecu. What problems are you having/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trecool44 »</TD></TR><TR><TD CLASS="quote">Yes I have a problem. I have chipped 4 p28's before with no problem. This one is a virgin p28 auto. When done it would not run from the code on the chip, it would just run on the stock map. The 550 injectors didnt like that. I dont know whats wrong with the ecu. What problems are you having/</TD></TR></TABLE>
sounds like your J1 is not jumped right, if your still on the internal maps and cant get the external ones to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">
sounds like your J1 is not jumped right, if your still on the internal maps and cant get the external ones to work.</TD></TR></TABLE>
x2
If J1 jumper isnt making a good connection, it will run on the stock map. try re-soldering it.
x2
1990accordpnw
Jan 22, 2015 03:55 PM
