What kind of hp and tq do I need to run 11's on DR tires? (TURBO HONDA B_SERIES)
you can easily get into the 11's with an old school bolt on kit(revhard stage 2) on a bone stock longblock(b16,ls, or gsr) i bet you could do it with ~280hp on drag radials.
I AGREE with d turbo
my setup 10 psi, went 11.57 at mid 120s, basically a 300hp setup
of course car made 200 more hp and ive only to accomplish 1140s at low 130s so speed and power is not the issues, traction and getting the car outta the hole is were its at
good luck, of course this is in a 2400lbs eg chassis as well full interior Power Street car
Good luck to all
d
Good luck to all
d
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">you can easily get into the 11's with an old school bolt on kit(revhard stage 2) on a bone stock longblock(b16,ls, or gsr) i bet you could do it with ~280hp on drag radials.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasteboyii »</TD></TR><TR><TD CLASS="quote">I AGREE with d turbo
Good luck to all
d</TD></TR></TABLE>
I agree with both of these guys.
Good luck to all
d</TD></TR></TABLE>
im gonna say about 315whp you can do it. im doing 12.5's at about 2680lbs.
theoretically if u match the time to a 2400lb car thats like 12.2. im also doing this with 2.0-2.1 60fts, so id bet if u get a good track or can cut 1.9-1.8s you can do high 11's
Most recently on completely bald BFG 225/50/15's I went 8.1 at 93 mph in the 1/8, and that was with a 2.0-2.1 60'. This is with a little over 300whp on a garbage track. That same track with old small 22' slicks I went 7.74 at 97mph and that was with a 1.90 something 60'.
That is the worst my car has ever spun that night with the BFGs. I was having to actually drive the car down the track because it was trying to go everywhere but straight. On top of that I thought I broke my tranny on that run as well
yeah PRP track prep is lacking big time.... doing high 11's with that power is pretty damn good
i could definately see 300whp being about average for higher 11 second passes. in a 2200-2500 lb car
B18c5 with Garret t4 ball-bearing turbo,low boost, CTR tranny
, BF Drag radials, ATC clutch, 92 Civic hatch nothing gutted. ANY advice? 2nd gear burnout?
this was last week spinning real real bad with a few hickups
http://s100.photobucket.com/al...5.flv
this is nopi NY
http://s114.photobucket.com/al...7.flv
both bfg passes
pmed u
this is nopi NY
both bfg passes
pmed u
mitsuman
28
Aug 3, 2004 08:03 AM
