map sensor vacum line...
Old Sep 21, 2006 | 10:04 PM
90b20vteckidd's Avatar
Default map sensor vacum line...
anyone know a way to bypass the map sensor vacum line? i am talking about the one that goes into the top of the throttle body. any help is sooo awesome
Old Sep 22, 2006 | 03:11 AM
crxnj's Avatar
Default Re: map sensor vacum line... (90b20vteckidd)
you need that vacuum line for the map sensor,,,unless you mean something else?
Old Sep 22, 2006 | 03:12 AM
civickiller's Avatar
Default Re: map sensor vacum line... (Mr.speaker)
only way to get rid of that vacuum line is to get a tb with the map sensor on top of the tb
Old Sep 22, 2006 | 11:19 AM
OK i see. if i do this, will i need to re-wire anything?
Old Sep 22, 2006 | 12:35 PM
Default Re: (90b20vteckidd)
nope i didnt, i just took the plug from the firewall and put it on the tb
Old Sep 22, 2006 | 05:41 PM
ok so if i just plug in the original map sensor connector to the new one on top of the tb, what would i do with all the vacum hoses ( the one going to the charcoal cannister, etc. )
Old Sep 22, 2006 | 09:32 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90b20vteckidd &raquo;</TD></TR><TR><TD CLASS="quote">ok so if i just plug in the original map sensor connector to the new one on top of the tb, what would i do with all the vacum hoses ( the one going to the charcoal cannister, etc. )</TD></TR></TABLE>
you can remove all that stuff..canister,original map sensor,purge solenoid,and all the vacuum hoese,,you dont need any of that stuff to begin with besides the map sensor...if you have emissions you need it though ,
Old Sep 24, 2006 | 11:06 AM
ok so if i remove all the hoses and original map sensor, do i just plug all the things that used to have hoses to them....like the one on the back of the intake manifold?. secondly, there are two connectors that go to the map sensor, do i only use one?
Old Sep 24, 2006 | 11:10 AM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90b20vteckidd &raquo;</TD></TR><TR><TD CLASS="quote">ok so if i remove all the hoses and original map sensor, do i just plug all the things that used to have hoses to them....like the one on the back of the intake manifold?. secondly, there are two connectors that go to the map sensor, do i only use one?</TD></TR></TABLE>
yup,plug em
theyre not both for the MAP...the 3 wire connector is for the MAP and the small 2 wire is for the purge solenoid
Old Sep 24, 2006 | 11:21 AM
awesome! thanks for the help man
Old Sep 24, 2006 | 11:56 AM
Suck my DX's Avatar
no problem
Old Sep 27, 2006 | 10:40 AM
4gencivicef9's Avatar
I have similar problem, I wanted to know if I could do basically the same thing, BUT with all of the stuff un hooked and just the map pluged in will the CEL light be on...? also will the car run right....is there any benefits of going to that map ....
and is a 68mm to big to put on a b16a and 310cc and stock comp...?
Old Sep 27, 2006 | 12:31 PM
Default Re: (Suck my DX)
bump
Old Sep 27, 2006 | 12:53 PM
Suck my DX's Avatar
Default Re: map sensor vacum line... (4gencivicef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 &raquo;</TD></TR><TR><TD CLASS="quote">I have similar problem, I wanted to know if I could do basically the same thing, BUT with all of the stuff un hooked and just the map pluged in will the CEL light be on...? also will the car run right....is there any benefits of going to that map ....
and is a 68mm to big to put on a b16a and 310cc and stock comp...?</TD></TR></TABLE>
you need to plug up anything u unhook...the CEL wont come on if everything is in working order...the other plug is just for the purge solenoid...its smog equipment...
68 is way too big for that motor and so are those injectors...i have a 64-62 mm tapered TB on my 11:1 CR b16
Old Sep 27, 2006 | 01:32 PM
Default Re: map sensor vacum line... (Suck my DX)
well I got it for when I go turbo, what size can I run without losing power and run right.... same for the injectors....
Old Sep 27, 2006 | 01:36 PM
CRX_1.8T's Avatar
I would go ahead and get some bigger injectors than that. Chances are, you are going to increase the power on your turbo setup anyways, no sense in having lame 310's on there unless you have an N/A engine or actually want to be bottlenecked in the lower end of the 200's with whp.
Old Sep 27, 2006 | 02:04 PM
Suck my DX's Avatar
Default Re: map sensor vacum line... (CRX_1.8T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">I would go ahead and get some bigger injectors than that. Chances are, you are going to increase the power on your turbo setup anyways, no sense in having lame 310's on there unless you have an N/A engine or actually want to be bottlenecked in the lower end of the 200's with whp.</TD></TR></TABLE>
id still leave the stock parts on until you boost...
Old Sep 27, 2006 | 06:03 PM
yea I hear you on that one, nah I wanted to know can I run then on the motor now the stock ones are 240cc, I figured 310cc cant be that bad, worst is I might be real rich... right ?
also with the t.b. being stock is 58, I have a 68mm if I bolt it on will I lose power because of the size I plan on chipping my p28 I am trying to go obd1 and I need the t.b. for the map sensor and injectors for tuning purposes lol
let me know what would be the right thing to do I need advice b16 I want it to get more power....and also run right lol
Charlie Moua
Apr 13, 2012 08:24 PM
da9blk1
Oct 16, 2007 02:41 AM
Topdawgg
Jun 25, 2007 10:02 AM
vtecn8ive
Jun 19, 2005 12:10 PM
