stick welder suggestions
im looking to do little projects and be able to weld metals together.
can anyone give me some recomendations for a basic stick welder that will run on 125volts
what should i look for, etc.
thank you
m
thank you
m
its actualy not for automotive apps. I wanted to get into creating metal art type structures and also get into pulse jet engines, I figured stick would be the cheapest route. Im open to any suggestions or opinions you guys have.
thank you
marcin
thank you
marcin
Ah pulse jet engines, they use an ungodly amount of fuel compared to a gas turbine
The cheapest route would be oxyacetylene welding (gas welding) would probably be the cheapest. You might want to back purge too but im not sure if that matters much for a pulse jet, that makes it so the inside of the pipe/tube weld is smooth(er).
i have a little harbor freight Hobby arc stick welder i can use it with 115 or 230 (dryer outlet) it works pretty good it can weld pretty thick metal. stick is the way to go if you are just looking for strength
