h22 in EK Swap.. won't start.
I completed the h22a4 swap, and had Ryan @ Rywire do my harness for me, but I can't get the car to start. We have spark, we have fuel to the rail, but it doesn't seem like the injectors are letting fuel through. The starter just cranks over, but won't do anything beyond that.
Can anyone help out?
check all your grounds....
i had a bad ground & it was messing with everything....would be very hard to start & the alt wasn't charging my battery good, bad idle...it had things all messed up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmayhew »</TD></TR><TR><TD CLASS="quote">check all your grounds....
i had a bad ground & it was messing with everything....would be very hard to start & the alt wasn't charging my battery good, bad idle...it had things all messed up</TD></TR></TABLE>
Checked, double checked, and then checked again, several times everyday. We've got the ECU ground which goes to the T-Stat housing, the valve cover ground.. battery ground, and the transmission/starter ground. Not sure what else it could be..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm_EJ6 »</TD></TR><TR><TD CLASS="quote">Update: Injectors 1 & 3 are squirting out. More so a drizzle, it doesn't seem too powerful, while 2 & 4 are doing nothing.</TD></TR></TABLE>
You getting the 12v feed to the injectors? The yellow/black (or red/black) wire. it should have 12v with key on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm_EJ6 »</TD></TR><TR><TD CLASS="quote">yeah, we have power to the injectors.</TD></TR></TABLE>
You check the injectors by applying power and ground to them (off the car of course)? It maybe a injector issue
Kaitosenin
14
Aug 30, 2010 04:25 PM
Rob_Dog
15
Nov 10, 2004 08:58 PM
