how hard is it to change tranny fluid??
Old Sep 21, 2006 | 08:45 PM
ilikeric3's Avatar
Default how hard is it to change tranny fluid??
well im doing all the maintenance stuff on my car since its about to be 150k miles and the tranny is up next. i was wondering how hard is it to change the tranny fluid? is it really hard? would i be better off going to a jiffy lube or something and have them do it? if its quite easy i would rather save the money and accomplish this myself
Old Sep 21, 2006 | 08:48 PM
crxnj's Avatar
Default Re: how hard is it to change tranny fluid?? (ilikeric3)
its just like changing the oil,,jack up car,drain tranny fluid,then fill with 1.9 qt (d-series). theres a shitload of places to fill,,the actual fill plug is a pain in the *** cause of where it is so most people use other places ,,like reverse light,speedo,etc
Old Sep 21, 2006 | 08:50 PM
ilikeric3's Avatar
so where would be the easiest place to fill it up at?
Old Sep 21, 2006 | 09:03 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikeric3 &raquo;</TD></TR><TR><TD CLASS="quote">so where would be the easiest place to fill it up at?</TD></TR></TABLE>
i always use the reverse light switch
Old Sep 21, 2006 | 09:31 PM
ilikeric3's Avatar
where that located at? and how do i know if its full?
Old Sep 21, 2006 | 09:34 PM
bag's Avatar
bag
Default Re: (ilikeric3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikeric3 &raquo;</TD></TR><TR><TD CLASS="quote">where that located at? and how do i know if its full?</TD></TR></TABLE>
get 2 qt of fluid and fill theres no way to overfill ,but even if you did the **** burns out
i use the speed hole personaly cause with the reverse it goes down to slow and i got no patience
Old Sep 21, 2006 | 09:48 PM
ilikeric3's Avatar
so where this speed hole you speak of
Old Sep 23, 2006 | 10:00 AM
LatnKng's Avatar
Its fairly eazy to do yourself. Just raise it up on jackstands up front, then loosen the 17 or 19mm nut or drain plug, after it drains just lower the car close to the ground and run a funnel with like a rubber hose or something of that sort into the same drain plug, make sure that the hose fits in the hole first, have someone pour it from the top while u hold the hose in the hole at the bottom until u see drops coming out the plug hole, let it leak first slightly then put the nut back on, that simple, about 1 hour or 45minutes. Make sure that u use 10w30 motor oil instead of tranny oil because it runs smoother and is not thin like your tranny oil, which tends to burn faster, just my suggestion. Should be a breeze..GOOD LUCK.
Old Sep 23, 2006 | 12:40 PM
ilikeric3's Avatar
really so its better to use motor oil instead of tranny fluid?
Old Sep 23, 2006 | 02:13 PM
CRXperiment's Avatar
I'd say run Honda MTF.
Old Sep 25, 2006 | 06:54 PM
LatnKng's Avatar
I think it is, i've never had any problems with it, using motor oil that is. Tranny fluid works too, but its too thin and burns faster, motor oil works better in my opinion, lasts longer.
Old Sep 26, 2006 | 06:28 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikeric3 &raquo;</TD></TR><TR><TD CLASS="quote">really so its better to use motor oil instead of tranny fluid?</TD></TR></TABLE>
This has been debated over and over. Be smart. Use Honda MTF.
Old Sep 26, 2006 | 09:22 AM
Kalokohan's Avatar
New User
Default Re: (wiZCo)
Does anyone have a pic of the speedo hole or reverse light hole?
Old Sep 26, 2006 | 05:42 PM
ilikeric3's Avatar
how about pennzoil synchromesh? i heard people had good exp. with it.
Old Sep 28, 2006 | 04:12 PM
1 Fly SI's Avatar
Default Re: how hard is it to change tranny fluid?? (LatnKng)
Don't ever use tranny fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LatnKng &raquo;</TD></TR><TR><TD CLASS="quote">Its fairly eazy to do yourself. Just raise it up on jackstands up front, then loosen the 17 or 19mm nut or drain plug, after it drains just lower the car close to the ground and run a funnel with like a rubber hose or something of that sort into the same drain plug, make sure that the hose fits in the hole first, have someone pour it from the top while u hold the hose in the hole at the bottom until u see drops coming out the plug hole, let it leak first slightly then put the nut back on, that simple, about 1 hour or 45minutes. Make sure that u use 10w30 motor oil instead of tranny oil because it runs smoother and is not thin like your tranny oil, which tends to burn faster, just my suggestion. Should be a breeze..GOOD LUCK. </TD></TR></TABLE>
Old Sep 29, 2006 | 08:54 AM
JOE BD-0's Avatar
Default Re: (Kalokohan)
why not just use the hole that was made to add the Honda MTF in?
Old Sep 29, 2006 | 10:25 AM
ef9robert's Avatar
Default Re: (JOE BD-0)
location of this hole please?
Old Sep 29, 2006 | 11:42 AM
whiteknightef's Avatar
WTF is this guy talking about "hole that was made for honda MTF"
Old Sep 30, 2006 | 08:22 AM
JOE BD-0's Avatar
Default Re: (whiteknightef)
http://www.hondaautomotivepart...2.gif
bolt #11 in this photo shows the location where the Honda engineers placed the hole for you to fill your trans fluid.....they recommend Honda MTF.......Okay, maybe I need to further explain that MTF stands for Manual Transmission Fluid.......Sounds like if I continue, I'll probably need to explain alot more.....
I don't believe that I actually answered this guy...
Old Sep 30, 2006 | 12:56 PM
HondaHeddie's Avatar
Default Re: (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">get 2 qt of fluid and fill theres no way to overfill ,but even if you did the **** burns out
i use the speed hole personaly cause with the reverse it goes down to slow and i got no patience </TD></TR></TABLE>
If you dont use the actual fill plug you CAN overfill.
with the fill plug out you add oil till it runs out the fill hole.
Old Sep 30, 2006 | 01:01 PM
sounds like they are talking about automatic transmission fluid which should NEVER be put in a manual civic/crx tranny.
Appologies if u guys did not mean atf
The factory recommends Honda MTF(manual transmission fluid), or motor oil 10w-30, or 40....20w-50....straight 30w, depending on temperature outside.
Old Sep 30, 2006 | 01:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikeric3 &raquo;</TD></TR><TR><TD CLASS="quote">how about pennzoil synchromesh? i heard people had good exp. with it.</TD></TR></TABLE>
https://honda-tech.com/zerothread/1763821
Old Sep 30, 2006 | 01:52 PM
EJREX's Avatar
Default Re: (HondaHeddie)
Use Honda MTF!
Old Oct 1, 2006 | 11:13 PM
Default Re: (EJREX)
that "#11 hole" is a bitch to fill ! use another one of the suggestions above for a easier fill. But do leave the suggested #11 hole open for correct fill hieght.
mikeintegra93
Jan 9, 2009 04:12 PM
Bigwool
Dec 17, 2004 07:56 PM
luciffer
Sep 13, 2004 11:24 AM
dork
Jul 9, 2004 09:27 AM
TypeRuz
Oct 28, 2003 04:58 PM
