How to install jdm eg window visors?
Im sure there were alot of posts about this but it doesn't really answer my questions. Mine has clips not the kind u bolt on. Im curious if it is about the same setup to have it installed. If anyone has a link or just explain it to me that would be great.
Thanks,
Andy
Thanks,
Andy
Form what I did in my EG was
1. Remove the Weather strip (only)
2. Place the Window Visors.
3. Secure the clips with a flat screw driver.
4. Put back the Weather strip.
5. Repeat 1-4 in the other side.
6. You're done.
I will get you some pics in a bit
6. You're done.
I appreciate it bro. My other question is i don't have those screws atleast with mine i didnt have any. Although from the looks of it they might just clip only. But the pics would help alot. Thanks
yeah we have the same car !!
this is the best I found : CRV Visors
they are from a CRV but you get the point! (just for visual reference)
REMOVE THE DOOR GLASS RUN CHANNEL ONLY from there is comon sense !! and the little flact screw driver (not to screw anything) just to secure the brackets!
I made a mistake is not the weather strips is the DOOR GLASS RUN CHANNEL
man the weather strip is not goin back on very well for now i just rolled the window up the best i could and hope it just seals. Im sure nothing will leak but it doesn't roll up to nice. Let me know how to cure this issue.
https://honda-tech.com/zerothread?id=1740884
Don't pull the weather stripping past the mirror or that far down the pillar.
after you install the visors spray the weather stripping ( where the window goes in between) with silicone spray. roll the window up. then roll it back down and spray again. This helps the window move faster and stay on track. Remember spray inbetween the wedge that the window goes between.
Thanks i'll definetly do that didn't really think to much to spray some stuff like that. I just want that piece to go in nicely.
BoostedGSRBubble
Feb 9, 2009 02:16 PM
RED95EG6
Aug 3, 2007 06:15 PM
EH2_pReStO
Jun 23, 2004 12:37 PM
