Loud knocking noise from passenger wheel well.?
Old Sep 21, 2006 | 06:54 PM
Ming Tsai's Avatar
Default Loud knocking noise from passenger wheel well.?
ok just as the title stats... there is this clink-clank noise from the passenger side wheel well when I drive on bumpy surfaces. The road whould have to be brand newly paved smooth to not hear the noise. Sounds alot like something is not bolted tight enough and loose, a clink and clank knocking sound.
anyways, i assumed it was the axle.. so I replaced that... still makes that noise. My friend said it could be loose breaks or it could be my steering knuckle.
anyone out there got any insight on this... I need to isolate the problem.. thanks guys.
Old Sep 21, 2006 | 07:04 PM
Syndacate's Avatar
Default Re: Loud knocking noise from passenger wheel well.? (Ming Tsai)
Probably a suspension piece. Maybe a balljoint. There's only 10,000 possibilities based on the discription you gave us.
Old Sep 21, 2006 | 07:19 PM
ek_chris's Avatar
why would you replace the axle? Jack the car up.. shake the wheel at 6 and 12 and 3 and 9, check for play
Old Sep 21, 2006 | 09:45 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (ek_chris)
check all bolts, check upper/lower control arm bushings, ball joints, etc
Old Sep 21, 2006 | 10:47 PM
ridin98civic's Avatar
Default Re: (Evs-One)
sounds like what my girlfriends nissan was doing, pass. rear hub bearing was shot. slid it off and it fell to pieces. only has 30,000 miles on it, i love honda
Old Sep 21, 2006 | 11:27 PM
4dohs4mohoes's Avatar
Default Re: (ridin98civic)
I will bet you 50 bucks it is your upper strut mount.
leave the car on the ground and tighten the strut bolt. If not, your strut is blown.
Old Sep 22, 2006 | 09:00 AM
Ming Tsai's Avatar
Default Re: (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees &raquo;</TD></TR><TR><TD CLASS="quote">I will bet you 50 bucks it is your upper strut mount.
leave the car on the ground and tighten the strut bolt. If not, your strut is blown.</TD></TR></TABLE>
hmmm... that might be it.. my brother told me his friend had the same problem and it was a loose strut bolt. I'm gonna have to check that after work.. hopefully it isn't a blown strut.
Old Sep 22, 2006 | 09:05 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (Ming Tsai)
Could very easily be an LCA bushing as well. Check them.
Geoshanna
May 20, 2013 07:27 AM
dopesk8er87
27
Apr 9, 2013 07:51 PM
jayare05
Nov 25, 2012 08:21 AM
-faded-
Nov 7, 2007 11:26 AM
sf89lx
Aug 26, 2004 10:05 AM
