d16y8 build help
Old Sep 21, 2006 | 06:27 PM
phan321's Avatar
Default d16y8 build help
Hi, i have a stock 99 ex civic and i'm wanting to build it n/a. This is going to be my first time building a civic and i dont want to start with a b-series motor cuz i dont wanna mess anything up and waste money. I wanna do this for the experience then move onto a b-series. Can you guys help me start this up. I would like to start with what ever bolt-ons i need and then move on to motor work. I want to end up getting atleast 150 whp.
Thanks a bunch guys for all the help!!!
Old Sep 21, 2006 | 06:34 PM
Syndacate's Avatar
Default Re: d16y8 build help (phan321)
You don't want to go B because you dont' want to waste any money? Are you kidding me? Making (or trying to make) 150whp NA on a D series <u>IS</u> wasting money. So much machine work, so expensive. Not much will be left that will make it a D series anymore.
EDIT:
It'll probalby put you down as much if not more than a B16 swap to build a D16 to 150 naturally aspired whp.
Old Sep 21, 2006 | 07:16 PM
divisionskate's Avatar
Default Re: d16y8 build help (Syndacate)
dont listen to him, im doing the same thing my self, but also looking for 190 or so with nos. heres some good links.
https://honda-tech.com/zerothread?id=335078
http://www.d-series.org/forums...21761
https://honda-tech.com/zero...age=1
Old Sep 21, 2006 | 08:52 PM
tn's Avatar
tn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by divisionskate &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to him, im doing the same thing my self, but also looking for 190 or so with nos. heres some good links.
https://honda-tech.com/zero...age=1</TD></TR></TABLE>
Old Sep 23, 2006 | 10:44 PM
phan321's Avatar
bump
Old Sep 23, 2006 | 10:55 PM
EJAYATE's Avatar
I Deliver
Nitrous will get you there really cheap!!!! I have a wet 75 shot with I/H/E and ported Intake manifold... and wow it's nice.
Old Sep 25, 2006 | 02:01 PM
phan321's Avatar
doesnt the nitrous ruin the motor quick?
Old Sep 25, 2006 | 04:10 PM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">You don't want to go B because you dont' want to waste any money? Are you kidding me? Making (or trying to make) 150whp NA on a D series <u>IS</u> wasting money. So much machine work, so expensive. Not much will be left that will make it a D series anymore.
EDIT:
It'll probalby put you down as much if not more than a B16 swap to build a D16 to 150 naturally aspired whp.</TD></TR></TABLE> hes playin it safe. polly doesnt dart money
Old Sep 25, 2006 | 09:52 PM
phan321's Avatar
oh
Old Sep 25, 2006 | 10:24 PM
SovXietday's Avatar
EDIT:
Bud, just so you know, if you want 150whp out of a N/A Dseries, you're going to need to pull the engine apart.
Oh, and don't cheap out on ANYTHING. DCsports headers are NOT a performance mod.
Old Sep 27, 2006 | 06:47 PM
phan321's Avatar
so are you suggesting that i should just do a motor swap?
Isnt there legal problems for putting a motor that is older than my car model in my car?
i also dont wanna spend to much so the only good motor i would be able to afford is an older b16a motor. I also saw that i would have to change from obd2 to obd1. Is there any disadvanages from going from 2 to 1?
Old Sep 27, 2006 | 06:52 PM
THC07's Avatar
Default Re: (phan321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan321 &raquo;</TD></TR><TR><TD CLASS="quote">so are you suggesting that i should just do a motor swap?
i also dont wanna spend to much so the only good motor i would be able to afford is an older b16a motor. I also saw that i would have to change from obd2 to obd1. Is there any disadvanages from going from 2 to 1?</TD></TR></TABLE>
Take what <U>Syndacate</U> said seriously, WASTE OF BLOOTIE MONEY. yes buy a swap, but dont go to obd1. say 2. if you cant afford that then you definitely cant afford to build any motor.
Old Sep 27, 2006 | 07:05 PM
BEYAAAH's Avatar
Default Re: (THC1107)
Save your money. Don't build your D or go B16. Wait until you have some ample cash from a summer job or something and buy a b18 or something. You'll probably be happier in the long run. If you get halfway into building your D and realize its not worth it, your gonna be bummed.
But thats only what I would do. Whatever you do, GL
Old Sep 27, 2006 | 10:27 PM
EJAYATE's Avatar
I Deliver
Beat a b18c1 (quite a few mods too) ej8 easily with the juice. HHhhmmmm 500 for juice or 1500+ for swap with mods. Easy choice. BTW I've sprayed over 30 lbs in 10 days with no problems. Zex wet kit is safe and easy.
Old Sep 27, 2006 | 10:36 PM
Froth's Avatar
Default Re: (B2CivMan)
I've always been a fan of "always there" power, Nitrous makes me angry but it DOES get the job done for fairly cheap but you're also kidding yourself because it's not "ALL MOTOR" with Nitrous. Weigh your options out very well, don't jump into something just because it could net you a small gain in power. Save your money, drive the D16 for a while until you decide what you REALLY want to do.
All motor D IS an option, it's not common and there's not alot of support for it. Will you be able to run sub 14's in a streetable setup? Doubtful.
Bottom line: Save your money, think it out and get something that has TRUE N/A potential.
Old Sep 27, 2006 | 10:47 PM
EJAYATE's Avatar
I Deliver
Default Re: (Froth)
Theres plenty of aftermarket support for the d. You can build a pretty quick d motor using oem parts.
Old Sep 28, 2006 | 12:30 AM
Froth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2CivMan &raquo;</TD></TR><TR><TD CLASS="quote">Theres plenty of aftermarket support for the d. You can build a pretty quick d motor using oem parts.</TD></TR></TABLE>
Depends on your definition of "pretty quick" I grew up around Sub 10 second muscle cars all my life, For me...pretty quick implies mid 12's or lower. For my definition, that's not going to happen for a N/A D-series with OEM parts.
Tbone
744
Feb 15, 2013 02:07 PM
Joni Teppo
10
Nov 24, 2012 04:44 PM
jdmeksedan666
10
Aug 1, 2009 09:46 AM
x4and3r1991
Mar 14, 2008 10:58 AM
jdm236
Sep 14, 2006 11:06 AM
