does air filter material matter
Old Sep 21, 2006 | 04:24 PM
ilikeric3's Avatar
Default does air filter material matter
well its about time to change my air filter and i was wondering if those k&n filters are better then the paper filters. the k&n cost like 30 bucks and i wanna know if its worth it then just getting a regular paper filter which is like 10 bucks.
Old Sep 21, 2006 | 04:27 PM
iphatcrxi's Avatar
Default Re: does air filter material matter (ilikeric3)
get the k&n its worth it
Old Sep 21, 2006 | 04:34 PM
omg_an_ef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikeric3 &raquo;</TD></TR><TR><TD CLASS="quote">well its about time to change my air filter and i was wondering if those k&n filters are better then the paper filters. the k&n cost like 30 bucks and i wanna know if its worth it then just getting a regular paper filter which is like 10 bucks.</TD></TR></TABLE>
Yes the materials matter. I personally have a K&N filter, while it didn't add 'mad vtak yo' to my car's acceleration, it is proven to flow ALOT better than cheap paper made filters; which when hit with dirt/dust/objects tend to clog, which is why they should be replaced every 10k miles. K&N Filters have like a crosshatch design before the actual filter which catches dust/dirt. The oil on the filters also cling to dust/dirt.
Old Sep 21, 2006 | 04:35 PM
macbasq's Avatar
If you don't want to clean and oil the filter, stick with the regular replacement (Fram or whatever). If it's not an issue, get the K&N, and just clean it every so often as needed (50K or less, depending on conditions).
Old Sep 21, 2006 | 05:38 PM
Maxximtl's Avatar
The trouble with the K&N is that its been proven not to filter as well as a stock paper element filter.. The additional flow comes at the expense of filtering capability. There have been numerous tests done that show minimal to no gains by using the K&N drop in filters. It would only make a difference if you are exceeding the flow capability of the filter you are currently using.....in our case, that doesn't necessarily seem to be the case.
Just stick with the stock paper filter. It'll cost more after 36k miles, but consider the better filtration money in the bank.
Old Sep 21, 2006 | 07:11 PM
ilikeric3's Avatar
so im guessing im better off with the stock paper filter then getting the k&n since it doesnt filter as good as the paper one?
Old Sep 21, 2006 | 08:13 PM
rayzian's Avatar
Default Re: (ilikeric3)
What about a cheap paper cone filter vs a K&N/micro fibre/cotton/etc cone filter? Are the gains still pretty minimal?
Old Sep 21, 2006 | 08:41 PM
ilikeric3's Avatar
^^ yeaaa id like to know also
Old Sep 21, 2006 | 09:52 PM
CRXed's Avatar
Cheap cone filters, like the ones from ebay for 15 dollars, rust.
globy123
Apr 3, 2010 09:03 PM
skylinevo
Jul 7, 2006 08:47 AM
elpiar
Jun 2, 2006 07:30 AM
mrdeadman
May 3, 2006 01:19 PM
