Del Sol Unstable when top is off, Any help?
Old Sep 21, 2006 | 03:32 PM
DRKSol's Avatar
Default Del Sol Unstable when top is off, Any help?
I just bought my del sol and it has stock suspension.... when the top is off it seems wobbly or unstable but when the top is on it's fine. i know its because the top makes it stronger but does anyone know how to fix it so it does do that when the top is off?
Old Sep 21, 2006 | 03:39 PM
Stoich EG2's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (DRKSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRKSol &raquo;</TD></TR><TR><TD CLASS="quote">I just bought my del sol and it has stock suspension.... when the top is off it seems wobbly or unstable but when the top is on it's fine. i know its because the top makes it stronger but does anyone know how to fix it so it does do that when the top is off?</TD></TR></TABLE>
what did you expect when you bought a del sol? hahaha. have fun
Old Sep 21, 2006 | 05:31 PM
nsxmatt's Avatar
It's called cowl shake and most any car without a roof will have it. There is no fixing it as nothing is broke.
Old Sep 21, 2006 | 06:03 PM
DRKSol's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (nsxmatt)
theres no way of fixing it? non what so ever?
Old Sep 21, 2006 | 06:06 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
It's called cowl shake and most any car without a roof will have it. There is no fixing it as nothing is broke.</TD></TR></TABLE> I don't know, my friend has a Toyota Supra that has a targa top (much like the del sol's) and it doesn't shake like how he's describing.
Old Sep 21, 2006 | 06:38 PM
nsxmatt's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote"> I don't know, my friend has a Toyota Supra that has a targa top (much like the del sol's) and it doesn't shake like how he's describing.</TD></TR></TABLE>
That's great, and would have been useful if we were talking about a Supra. Different cars will respond different to losing the top half of the unibody. Almost all will have some form of cowl shake, some worse than others. After owning a few Del Sol's and rode in others I can say the car has bad cowl shake when the roof is off the car and is a normal trait.
Old Sep 21, 2006 | 07:46 PM
Falqon's Avatar
I own a Del Sol, and the car doesn't shake like he's describing, what's your point?
Sounds like some serious placebo affect going on.
Old Sep 21, 2006 | 08:12 PM
GG99's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (Falqon)
strut bars...and a roll cage
Old Sep 21, 2006 | 08:17 PM
gotboostedvr6's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (GG99)
You dont notice your delsol flexing because you dont know what to look for. Try holding the windshield while driving and hit a few bumps youll see what they are refering to.
Old Sep 23, 2006 | 11:53 AM
Falqon's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (gotboostedvr6)
I would hardly describe something that requires holding the windshield and driving over bumps as "unstable" as the original poster did
Old Sep 23, 2006 | 12:18 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon &raquo;</TD></TR><TR><TD CLASS="quote">I would hardly describe something that requires holding the windshield and driving over bumps as "unstable" as the original poster did</TD></TR></TABLE>
And we are also going on someones opinion and first impressions of driving a Del Sol. I'm sure it's not as bad as people are playing this out to be.
Old Sep 23, 2006 | 12:55 PM
sohcvtec1995's Avatar
custom cage?
Old Sep 23, 2006 | 05:10 PM
derspi's Avatar
To the OP:
Define "wobbly."
Define "unstable."
Like others have said, if you're referring to cowl shake going over bumps and stuff, there's nothing to fix as there is nothing wrong with your Del Sol. If you're referring to aerodynamic instability (ie. on the freeway) I suggest you slow down when you have the top off!
Old Sep 23, 2006 | 07:44 PM
If a car flexes when you go over bumps what do you think it will do when your turning?
Old Sep 23, 2006 | 07:58 PM
solsi's Avatar
same here. only way to fix it is to strengthen the chassis(rollbars). Damn S2000 have that fancy X-bracing so they dont have this prob.
Old Sep 23, 2006 | 08:00 PM
Rodzknight's Avatar
roll bar i guess??????
thats the only thing that i can think of. b/c **** your taking off some of the reinforcement of the car when the top is off.
Old Sep 23, 2006 | 09:16 PM
Syndacate's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (Rodzknight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">That's great, and would have been useful if we were talking about a Supra. Different cars will respond different to losing the top half of the unibody. Almost all will have some form of cowl shake, some worse than others. After owning a few Del Sol's and rode in others I can say the car has bad cowl shake when the roof is off the car and is a normal trait.</TD></TR></TABLE>
Read first before you post - you said(paraphrased) "it happens to all cars with removable roofs"
The concept of the toyota supra's targa top and the del sol's targa top is the same. My point was simple, it rejects his saying that it happens to all cars wtih removalable roofs. My friend has a Supra, it ISN'T unstable when the top is off.
So stick it.
Old Sep 23, 2006 | 09:18 PM
JCracer723's Avatar
1. bolt on cage/reinforcement bars(safety 21 and thats what i just installed)
2. custom cage(big bux)
3. custom x brace (underneath the floor but not enough space)
4. chassis foam (messy but i heard well worth it)
Old Sep 24, 2006 | 06:03 AM
Heath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Read first before you post - you said(paraphrased) "it happens to all cars with removable roofs"
So stick it.</TD></TR></TABLE>
What are you talking about? The above statement would be like me saying; "I used to have a 92 MR2 and it sure as hell didn't shake when the top was off." It has no relevance to the OP. All that does is establish that some cars supposedly shake and others don't.
I think the OP was posting this to get the opinions of other sol owners to see if they had the same problem and if there was an easy fix, not if this were normal for targa vehicles. No matter what you say, the supra and every other targa vehicle are gonna be slightly less stable and a bit more squirrelly with the top off.
Old Sep 24, 2006 | 06:36 AM
Default Re: Del Sol Unstable when top is off, Any help? (Heath)
^ that sums it up
Old Sep 24, 2006 | 06:38 AM
nsxmatt's Avatar
Your a dipshit. Supra targas have cowl shake just the same as a Del sol. Look on Supra Forums if you don't believe me. They even make targa braces for high power cars to keep the cars from flexing.
Riding your friends nuts for his bias uneducated opinion does nothing to contribute to the thread, it just makes your post as stupid as the rest you post here because you don't include facts in any of them. You just run your mouth.
The original posters car is not unstable, he just has never been in a targa top car and is feeling normal cowl shake. And like I said before, most every car will have it in some form or another some worse than others.
So you sir can stick it.
Old Sep 24, 2006 | 07:19 AM
BenSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GG99 &raquo;</TD></TR><TR><TD CLASS="quote">strut bars...and a roll cage </TD></TR></TABLE>
Old Sep 24, 2006 | 08:28 AM
Heath's Avatar
Default Re: Del Sol Unstable when top is off, Any help? (BenSol)
****** A Matt, didn't realize I was defending your post until just now. Haha.
Old Sep 24, 2006 | 09:21 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heath &raquo;</TD></TR><TR><TD CLASS="quote">****** A Matt, didn't realize I was defending your post until just now. Haha.</TD></TR></TABLE>
lol,
Old Sep 24, 2006 | 12:05 PM
Stoich EG2's Avatar
someone make a targa brace for a del sol
