Black smoke!!
Old Sep 21, 2006 | 02:57 PM
YodajdmEK4's Avatar
Default Black smoke Question!!
Everytime I go past 85mph or 90mph or 6000rpm in vtec my car shoots out small clouds of black smoke, what would cause that? I have 96 ek with a GSR swap, straight pipe out a Spoon NI exhaust
Old Sep 21, 2006 | 03:01 PM
lemon_juice's Avatar
Default Re: Black smoke Question!! (YodajdmEK4)
burning oil or running very rich
Old Sep 21, 2006 | 03:02 PM
YodajdmEK4's Avatar
Default Re: Black smoke Question!! (lemon_juice)
Its not burning oil cause i have kept a eye on the oil but its fine. How can I fix the car from running rich?
Old Sep 21, 2006 | 03:05 PM
on a basically stock (bolt-ons dont count) just try a basic maintanence to get her healthy. check spark plugs, injectors, i dunno...all those things
Old Sep 21, 2006 | 03:09 PM
YodajdmEK4's Avatar
Everything is pretty much new, I do have a CEL for the IACV , that is probably it but just though I might ask and check
Old Sep 21, 2006 | 03:10 PM
Syndacate's Avatar
Everything's fine. You said you're running straight pipe. The gas isn't burning up in the catalytic converter like it should, that's all. Unless you're getting shitty gas mileage or a ticket I wouldn't worry about it.
Oh, and about the IACV, doubt it's that. I've never seen a bad IACV produce black smoke. It could produce white smoke because it's coolant controlled and if you have a leak and there and it lands on the exhaust pipe you will be looking at white smoke in your rear view mirror. If you're throwing a black cloud out, I doubt it's because of the IACV.
Old Sep 21, 2006 | 03:12 PM
YodajdmEK4's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Everything's fine. You said you're running straight pipe. The gas isn't burning up in the catalytic converter like it should, that's all. Unless you're getting shitty gas mileage or a ticket I wouldn't worry about it.</TD></TR></TABLE>
Gas mileage is still good and I aint getting pulled over ( knock on wood ) ..
Old Sep 21, 2006 | 04:01 PM
Syndacate's Avatar
Default Re: (YodajdmEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YodajdmEK4 &raquo;</TD></TR><TR><TD CLASS="quote">
Gas mileage is still good and I aint getting pulled over ( knock on wood ) ..</TD></TR></TABLE>
Wouldn't sweat it, sounds like it's just from hard driving w/ a straight pipe. If it concerns you so much go to an exhaust shop and put a cat on it. Should go away.
Old Jun 29, 2007 | 07:28 PM
De_tour's Avatar
i have the same thing that happens when im in high rpms but i AM runing a cat.
Compression is 200 across, miles on the motor is around 120k. I do go through about a quart inbetween oil changes to keep things topped off and the oil is changed no longer then 3k. Oil is mobile 1 synthetic 10-30.
valve seals?
Old Jun 30, 2007 | 04:05 PM
De_tour's Avatar
Default Re: (De_tour)
up
Old Jun 30, 2007 | 06:04 PM
ke98248's Avatar
Make your own thread.
Fat Chick Magnet
Jul 8, 2006 02:31 PM
Teamdiesel
12
Apr 25, 2006 06:21 AM
suckanut
10
May 14, 2005 04:10 PM
egracer44
23
Oct 3, 2003 06:25 AM
KW2000
Sep 19, 2003 12:27 PM
