PCT pistons in B18C
Old Sep 21, 2006 | 09:48 AM
eg6madness's Avatar
Default PCT pistons in B18C
hey i have been doin some research and i realise that the PCT pistons yield a whoppin 12.0:1 CR in the GSR motor.
I want to know would i have clearence issues with the valves and pistons if i place them in my block ?
What about rods? can the stock GSR rods fit the pistons or will i have to mill a bit to make them fit?
would that throw off balance on the crank, if i mill the rods?
i am also thinking about getting Skunk 2 pro 2 cams?
what about clearence issues with these cams and the PCTs ?
Old Sep 21, 2006 | 10:26 AM
GSRCRXsi's Avatar
Default Re: PCT pistons in B18C (eg6madness)
compression is more like 13:1
rods will fit the pistons fine
degree the cams and check your clearnaces to see if it will clear. no one can tell you for sure.
Old Sep 21, 2006 | 08:18 PM
eg6madness's Avatar
Default Re: PCT pistons in B18C (GSRCRXsi)
oh wow....i was hoping it was aroudn 12.0:1.
with skunk cams i really think i may be risking my pistons slappin the valves. are there any other stock honda piston that carry me to around 11.4-12.0 in a GSR block and GSR head
Old Sep 21, 2006 | 08:59 PM
all-mtr-teg's Avatar
I think the JDM type r pistons are much better for a gsr head and block. Comp. is around 12.0:1 if not, the JDM Gsr pistons are like high 10's low 11's. I was looking into the same thing for my 97 Gsr.
Old Sep 21, 2006 | 11:30 PM
ekgcool's Avatar
Default Re: PCT pistons in B18C (all-mtr-teg)
B16a pistons should get you near 11.5:1...If using a GSR head...If you need 12.0:1 get flat faced valves and/or a thinner head gasket...I thought PCT pistons in a GSR block made 12.5:1, while a LS-VTEC using PCT pistons would yeild closer to 13.0:1??!! Hmmm
Old Sep 22, 2006 | 04:01 AM
Player5530's Avatar
if you could see if you can trade ur GSR head for a B16 head. that will lower your Compression ratio. I have PCT's in a GSR block with B16 head with out flat valves and if i remember right my compression is 12.3:1 You wont have any clearance issues with that setup.
Old Sep 23, 2006 | 03:30 PM
eg6madness's Avatar
Default Re: (Player5530)
ok sounds cool. It is a JDM B18C that i have right now. i want to bump the compression.
would it really be good to get the PTC or would i be better off gettin High comp forged pistons?
sick93sol
Oct 3, 2007 12:44 PM
dragEF8
Jun 16, 2004 11:48 AM
Licensed2Spool
May 6, 2003 08:46 AM
