GSR pistons in a B18A
Old Mar 30, 2003 | 09:53 PM
Licensed2Spool's Avatar
Default GSR pistons in a B18A
Will gsr pistons fit in a b18a block without modification?
Old Mar 30, 2003 | 11:23 PM
Ben Huynh's Avatar
Default Re: GSR pistons in a B18A (Licensed2Spool)
We use B18C1 pistons in B18Bs on occasion. I assume B18A would be the same.
Old May 6, 2003 | 06:22 AM
nick.na's Avatar
Default Re: GSR pistons in a B18A (ben@importparts.com)
would there be any benefits to using these? no modifications necessary, correct? How about B17 pistons? any improvement at all over b18 pistons?
Old May 6, 2003 | 06:30 AM
93LSivic's Avatar
Im using JE gsr flattop 9.8:1 pistons in my sleeved LS (b18a block). No problems at all, its all the same bore.
But...........
The valve reliefs are cut differently between the vtec and nonvtec. They are ok to use with stock cams, but if your gonna run some wild high lift cams you will want to clay the motor. Headgasket thickness will also play a role obviously.
This is my problem right now. I never bothered claying my motor during assembly, so i have no idea if I can run a big cam in it. The head is coming off this week to replace guides so I guess I will clay it this time.
Old May 6, 2003 | 07:07 AM
nick.na's Avatar
Default Re: GSR pistons in a B18A (93LSivic)
what would be the benefits of adding these just stock...I have heard b16 pistons in an LS will mate to the rods with no milling....boosting compression.,...how about the gsr pistons?
Old May 6, 2003 | 08:46 AM
nick.na's Avatar
Default Re: GSR pistons in a B18A (amber-bling)
anyone? ( i know I am jacking this thread, but if the thread starter wants to know still, the info will be there for him
Targa4Life
Jul 5, 2008 11:16 AM
Wheelman-CZ
Jan 7, 2008 12:52 AM
c r x_s i
10
Aug 20, 2007 12:47 PM
tysir
Aug 16, 2001 08:32 AM
