38mm tial wastegate with 7.8 psi spring...how much boost?
Old Sep 20, 2006 | 06:48 PM
vg7z's Avatar
Default 38mm tial wastegate with 7.8 psi spring...how much boost?
I know this is a n00b question but im a little new to wastegates. Can someone explain to me what the spring rating means?? and hopw much boost it holds?
Old Sep 20, 2006 | 06:51 PM
urbansi's Avatar
Default Re: 38mm tial wastegate with 7.8 psi spring...how much boost? (vg7z)
thats all the boost you can make on that spring without a boost controller
As far as upping the boost you are going to either need to get a stiffer, or EBC or MBC
Old Sep 20, 2006 | 06:58 PM
Speed Infliction's Avatar
what ever the spring is rated is the lowest boost pressure you can boost. I think that asnswers your question.
Old Sep 20, 2006 | 07:03 PM
vg7z's Avatar
ive got a turboxs MBC but thanks you guys answeared my question
Old Sep 20, 2006 | 07:07 PM
honda1982's Avatar
Default Re: (vg7z)
the spring rate psi is the lowest boost (psi) you can used. so let said, with no boost controller the turbo will only go up to 7.8psi before the wastegate open. But with a boost controller you can up the psi to anything above 7.8psi (20psi if you want)....
Old Sep 20, 2006 | 07:29 PM
HamiltonRex's Avatar
Default Re: (honda1982)
rule of thumb... dont go double your WG spring pressure. IE 0.5bar spring, dont boost past 1bar on the spring.. Chances of creeping and spiking greatly increased, also you cant run lower then your spring pressure.
Old Sep 20, 2006 | 08:27 PM
JDMs1eeper's Avatar
Default Re: (HamiltonRex)
You'll want a larger wastegate depending on Manifold design and Turbine size you'll wanna have. The higher the boost the easier it is to control, its harder to control 5psi than 30psi.
Simple example.
84mm LSvtec, 8500 rpms.
35mm wastegate 6psi spring.
InlinePRO manifold
W/ a .63 AR turbine I was able to control 6psi all the way to 26psi, rock solid.
W/ a .84 AR turbine I was able to control 10-11psi all the way to 26psi, rock solid.
The .84 AR wouldnt run less than 10-11psi because the turbine was flowing so well exhaust was less willing to exit the gate to control 6psi.
This is just a basic example.
With a log manifold a 35 or 38mm is plenty depending on turbine AR size and intended low boost.
With a nice flowing tube manifold, a 38 or larger is a must. Some people use 2 38's or a 44mm to help maintain low boost pressure.
hope i helped.. some? its late and i'm tired
1990hondaHF
Jan 16, 2008 11:57 AM
92jdmhatch
May 4, 2004 12:10 AM
yusoslo
Jul 12, 2003 08:01 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
shingles
Jan 24, 2003 01:58 AM
