downpipe ?
Old Sep 20, 2006 | 07:43 PM
1158's Avatar
Default downpipe ?
I have my dp bolted onto the turbine housing, but I'm not sure if one of the nuts is tight enough. It's the one right under the bend, I can get a pic if needed, and it's a bitch. I think it's tight, but if I shine a flash light inside the housing, right at the seam between the dp and the housing I can see some faint light.
I can only see it in a pitch black room. It is very faint and can only be seen it the light is held on the seam. My question is, will thermal expansion fill this gap? I would think it will, but this is my first install and don't want to have to take the whole thing apart if it leaks. Thanks.
Old Sep 20, 2006 | 08:23 PM
inspyral's Avatar
If it's small enough, the carbon buildup would probably seal it. Otherwise, you can maybe try running a stud/nut on that hole. For extra sealing, you could get one of these:
Old Sep 20, 2006 | 08:27 PM
Wickedsol94's Avatar
If your others are tight it will be fine. I run 3 bolts on my 5 bolt. It leaked for about 50 miles. Carbon sealed it up. No leaks at all with 2 bolts missing.
Run it, if it leaks bad Id sujest buying a gasket and let carbon do the rest.
Old Sep 20, 2006 | 08:31 PM
1158's Avatar
I figure between thermal expansion and carbon build up it will seal, just wanted to make sure. The other 4 nuts are on tight. Thanks!
It is a stud/nut on the hole, just the dp is so close. It was perfect before I got it coated, but I didn't think about it when I had it coated. The coating is thick enough that it makes the nut a bitch to turn. I tried grinding it off, but was only able to do so much.
_jester_
Jan 28, 2005 03:58 AM
Tactic$
Oct 25, 2004 06:41 AM
crix180
Dec 1, 2003 04:50 PM
LSRydeR
Jan 24, 2003 03:52 PM
