How do you fix the wheel well after being hit?
Old Sep 20, 2006 | 06:07 PM
datssoled's Avatar
Default How do you fix the wheel well after being hit?
I read some how tos for replacing the fender but is there a way to fix the wheel well too? I was hit on the right fender only but it also pushed in and folded the wheel well too. Is there a way to just mold it back out? Or does it have to be replace?
Old Sep 20, 2006 | 06:08 PM
ZacCarter's Avatar
That is a frame rail, If that is bent it is going to have to go on a frame machine.
Old Sep 20, 2006 | 09:37 PM
datssoled's Avatar
Default Re: How do you fix the wheel well after being hit? (datssoled)
ooo so its called the frame rail? is it part of the body or can you take it off?
Old Sep 20, 2006 | 10:40 PM
amy's Avatar
amy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by datssoled &raquo;</TD></TR><TR><TD CLASS="quote">ooo so its called the frame rail? is it part of the body or can you take it off?</TD></TR></TABLE>
I thought that area was the sub-frame? it's there to crumple first in an accident to protect the rest of your frame - at least tahts what i thought......
but nope, it's part of the frame, the basis of your cars body - it's all welded togther and i don't think you wanna start messing with that stuff...... they put it on the frame pulling machine to straighten it out as best as possible but chances are it won't be 100% again
Old Sep 20, 2006 | 10:42 PM
Eran's Avatar
HT White Ops
It's a subframe rail. It's replaceable, but must be done at a body shop and be laser aligned. Civic's don't have a frame. We have a unibody.
Old Sep 20, 2006 | 11:19 PM
datssoled's Avatar
Default Re: (Eran)
whats the price tag on that about? i always thought it was called the wheel well
Old Sep 20, 2006 | 11:22 PM
Eran's Avatar
HT White Ops
Default Re: (datssoled)
well, it depends. Is it the lower part, or the upper part where the fender bolts to, the part the hood rests on?
Old Sep 21, 2006 | 07:10 AM
Kruzen510's Avatar
Default Re: (Eran)
First of all they do have frame rails in the front. If it smashed the fender then it probably went into the outter apron of the upper body structure and that is an easy fix. I highly doubht it went low enough to hit the frame rail, that would mean all the suspension would be messed up.
Old Sep 21, 2006 | 11:21 AM
datssoled's Avatar
well i researched a little and it seems as though the wheel well is actually the fender liner, where theres the front and rear fender liner. They are held in by 8mm bolts. Im guessing i could just take it off and mold it back in place and put it back on. Any suggestions?
Old Sep 21, 2006 | 11:34 AM
Eran's Avatar
HT White Ops
Oh, so the black part is crumpled? LOL
It's plastic.
Just go buy a new one from honda.
Old Sep 21, 2006 | 12:01 PM
civic123's Avatar
check it out at the shop, maybe it can be fix...
Old Sep 21, 2006 | 01:54 PM
datssoled's Avatar
is that part called the fender liner?
Old Sep 21, 2006 | 09:36 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by datssoled &raquo;</TD></TR><TR><TD CLASS="quote">is that part called the fender liner?</TD></TR></TABLE>
Just go to honda.
Old Sep 28, 2006 | 07:33 PM
datssoled's Avatar
Default Re: How do you fix the wheel well after being hit? (Eran)
Alright i took it off. Anyone know where I can get those plastic plugs for the fender liner? The old ones broke. And my frame was a little bit bent near the wire to the headlights. Is it okay if I just pound it a little?
Old Sep 28, 2006 | 07:54 PM
EG2Driver's Avatar
post a picture and we will tell you for sure what is and what is not broken. Go to a junkyard for the fenderliner, no point in paying full price for that part.
Demigod2019
Jun 9, 2019 10:45 AM
Demigod2019
Jun 9, 2019 07:01 AM
Importn2oRacer
Nov 26, 2010 01:41 PM
luckii
Suspension & Brakes
Aug 6, 2007 11:21 AM
Nameless Warrior
12
Nov 30, 2006 08:52 AM
