Bad gas?
Old Sep 20, 2006 | 11:20 AM
ogawa_jiei's Avatar
Default Bad gas?
Edited
Old Sep 20, 2006 | 02:11 PM
HondaJack's Avatar
Default Re: Bad gas? (ogawa_jiei)
First off the gas is bad for sure my man.
Second no engine should run on that ****. Change that gas our ASAP.
Old Sep 20, 2006 | 02:16 PM
cxSHOE's Avatar
my car has been sitting on jack stands since 9/2005 still starts up on one turn, and idles just fine. with cheap arco gas ($2.25 gallon)
i dont think its the gas. check your main relay, coil, and ignitor inside your distributor
Old Sep 20, 2006 | 02:21 PM
ogawa_jiei's Avatar
Default Re: Bad gas? (HondaJack)
Edited
Old Sep 20, 2006 | 02:26 PM
ogawa_jiei's Avatar
Default Re: Bad gas? (cxSHOE)
Edited
Old Sep 20, 2006 | 02:28 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogawa_jiei &raquo;</TD></TR><TR><TD CLASS="quote">Well, I just changed the old gas -- drained it out. Put new gas in but the engine still doesnt turn over. Same problem as before. </TD></TR></TABLE>
i knew it... gas will still start the car with a very rough idle but it will start it and keep running.
check your main relay, first. since it the most likey cause, you can use any 92-01 civic or integra main relay... use a friends.
doesnt work, then check to see if you have spark. no spark, switch out your ignitor, all 92-01 civic and integra's use the same ignitor..
still no spark. then check your coil all 92-01 civics and integas use the same coil.
Old Sep 20, 2006 | 02:31 PM
cxSHOE's Avatar
also jay, check your pm.. and load the eg manual... this will show you how to fix the car. should help in the future. make sure to download it to your harddrive.
Old Sep 20, 2006 | 02:48 PM
ogawa_jiei's Avatar
Edited
Old Sep 20, 2006 | 02:56 PM
Syndacate's Avatar
You said in your other topic that it's throwing a CEL when you try to start it. Go to this thread and check what CEL you're throwing.
Old Sep 20, 2006 | 03:07 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogawa_jiei &raquo;</TD></TR><TR><TD CLASS="quote">thanks again for your replies jackie. i checked for spark, no spark. what main relay are you talking about? there's a relay in the distributor? im gonna check it, gotta search for it for directions. my experience is limited to what I have dealt with in the past. but i will also check the main relay. </TD></TR></TABLE>
i pmed you.. and yes if you are getting a codes, check to see what the codes are if you dont have those extra parts to switch out.
Fighterinsnatch
Aug 7, 2008 09:16 AM
bausts
Mar 15, 2007 03:28 PM
JALOP B16
Feb 6, 2007 06:40 PM
1sikhatch
57
Mar 11, 2005 04:36 PM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
