Correct plug wires on the correct distributor terminals?
Old Sep 20, 2006 | 10:51 AM
ogawa_jiei's Avatar
Default Correct plug wires on the correct distributor terminals?
Edited
Old Sep 20, 2006 | 11:21 AM
ogawa_jiei's Avatar
Default Re: Correct plug wires on the correct distributor terminals? (ogawa_jiei)
Edited
Old Sep 20, 2006 | 11:23 AM
jadugartir's Avatar
gas WILL not sit for 2.5 years and still maintain its combustive properties unless you added fuel stabilizer since the beginning.
Old Sep 20, 2006 | 11:24 AM
schardbody's Avatar
search "firing order" for the answer to that, as for the no start, sounds like either a bad dizzy, ignition switch, or main relay. check the codes.
your description is vague, but if the CEL comes on and goes off then the main relay is most likely working. it will come back on again after cranking w/ no start after a few seconds and disable the dizzy.
Old Sep 20, 2006 | 11:31 AM
BogusMalone's Avatar
https://honda-tech.com/zerothread?id=1752275
Old Sep 20, 2006 | 11:53 AM
ogawa_jiei's Avatar
Edited
Old Sep 20, 2006 | 11:55 AM
ogawa_jiei's Avatar
Default Re: Correct plug wires on the correct distributor terminals? (jadugartir)
Edited
Old Sep 20, 2006 | 01:19 PM
schardbody's Avatar
bad gas STINKS, and will not burn.
Old Sep 20, 2006 | 01:39 PM
ogawa_jiei's Avatar
Default Re: (schardbody)
Edited
sikwitit
Apr 9, 2008 08:11 PM
DA_typeR
Aug 13, 2007 11:57 PM
bullwinkle777
Jul 21, 2007 06:18 PM
Warren
Apr 6, 2007 06:49 AM
jfrye
Jul 16, 2004 02:41 PM
