i searched!! h22a4 w/f22 crank and rods? is this possible
Old Sep 20, 2006 | 10:41 AM
djsire's Avatar
Default i searched!! h22a4 w/f22 crank and rods? is this possible
please let me know, i spun a bearing and have to rebuild anyway!
all i could find is doin it ot the h22a1 block.
Old Sep 20, 2006 | 11:03 AM
98vtec's Avatar
moderator emeritus
Default Re: i searched!! h22a4 w/f22 crank and rods? is this possible (djsire)
h22a1 = h22a4
only difference is the main journal sizes (depending on year) and that the a1 is closed deck and the a4 is open deck.
in short, yes it will work. It will increase your stroke which will in turn increase your dynamic (i think) compression.
There is a good bit of information regarding this topic. All you have to do is take a little time to do your own research
Old Sep 20, 2006 | 11:46 AM
MadCityLude
Guest
Posts: n/a
Default Re: i searched!! h22a4 w/f22 crank and rods? is this possible (98vtec)
IMO no it will not work. H22a4 have 55mm mains, the F22 are all 50mm.
Therefore the crank will not fit correctly in the block
Modified by MadCityLude at 3:06 PM 9/20/2006
Old Sep 20, 2006 | 11:47 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
only difference is the main journal sizes (depending on year) </TD></TR></TABLE>
That's the problem he has to overcome. And with an F22 crank (same as the H23 crank) it won't work if he is using a 98+ H22A4 block.
I would look into mating the F22 bottomend to the H22 head. Personally, I would go for the F23 bottomend, but that's just me.
Old Sep 20, 2006 | 12:38 PM
Chuckles99SH's Avatar
Default Re: i searched!! h22a4 w/f22 crank and rods? is this possible (AndyD)
If your crank and block arent that bad just have the tolerences checked, replace the bearings and micropolish rebuild, cheaper in the long run and **** will not take jerry rigging to get it built.
Old Sep 20, 2006 | 01:00 PM
fastludeh22's Avatar
Default Re: i searched!! h22a4 w/f22 crank and rods? is this possible (Chuckles99SH)
first off what year is the block? 97a4 f22/h23 yes will work
98+ will have to be f23, crazy stroke right there.
what ever you do keep the oil squirters, no matter what anyone tells you...
Old Sep 20, 2006 | 01:29 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: i searched!! h22a4 w/f22 crank and rods? is this possible (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">what ever you do keep the oil squirters, no matter what anyone tells you...</TD></TR></TABLE>
x2
Old Sep 21, 2006 | 06:18 AM
Default Re: i searched!! h22a4 w/f22 crank and rods? is this possible (AnthonyG2003)
oh ya just remembered, if the block is 98+ isnt the true h23a vtec cranks 55mm?
Old Sep 21, 2006 | 09:40 AM
djsire's Avatar
i was told it was a 98 block.
what kind of power is made just thorowing on the stock f23 block?
i want to make some power if im gonna rebuild it.
is it possible to use a 98 and up f22 rods and crank&gt;?
are the 55m?
help!
thanks for the answers
jdm_rb20
17
Mar 6, 2013 07:43 PM
hondahippy
May 5, 2006 11:50 AM
IAluder95
Mar 30, 2006 09:43 PM
bigblu333
Feb 10, 2004 04:58 PM
