Just ran across a '93 del sol for dirt cheap / need some power solutions.....pls/thnx
Old Sep 20, 2006 | 08:02 AM
mrxracing's Avatar
Default Just ran across a '93 del sol for dirt cheap / need some power solutions.....pls/thnx
So i work for a used car dealership and ran across this 93 del sol on a bid sheet, sooo..
Long story short, i am thinking b18 b1 w/ t3/t4 turb, big brakes, suspension, anti sways and strut bars...
Is there a better engine to go in this? Unfortunatly i'm not sure what engine is in it now, but for 150$ i don't see it running too well?
Basically, what would you do with an almost free Del sol??
Thanks alot for your input!
Old Sep 20, 2006 | 08:15 AM
LowSlow93Sol's Avatar
Default Re: Just ran across a '93 del sol for dirt cheap / need some power solutions.....pls/thnx (mrxracin
K-series?
For the money you could rebuild the D-series thats in it and make more than you would with the b18b setup.
Old Sep 20, 2006 | 08:23 AM
mhart's Avatar
b16
Old Sep 20, 2006 | 08:25 AM
Default Re: (mhart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhart &raquo;</TD></TR><TR><TD CLASS="quote">b16</TD></TR></TABLE> NO this is the worst option avalible unless you leave the stock D-series in there.
Old Sep 20, 2006 | 08:29 AM
Type X's Avatar
go k
Old Sep 20, 2006 | 08:31 AM
Kruzen510's Avatar
IMO gsr, or build up the d
Old Sep 20, 2006 | 08:33 AM
mrxracing's Avatar
Default Re: (LowSlow93Sol)
So would i still use forced induction or should i go with cams/springs/valves, etc.?
Are all del sol's the 1.6 vtec?
What kinda rebuild are you speaking of? thanks
sorry about the noob questions, i have always had integras and am not too familiar with these del sol's
Old Sep 20, 2006 | 08:34 AM
MonkeyBoy668's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrxracing &raquo;</TD></TR><TR><TD CLASS="quote">Basically, what would you do with an almost free Del sol??</TD></TR></TABLE>
Depends on how much time I had.
B16+S21 would be easiest, just source a Del Sol VTEC wiring harness, ECU, etc. and away you go.
A rear engine conversion would be sweet.
And a V8 wouldn't be a bad choice either.
Old Sep 20, 2006 | 08:36 AM
Default Re: (mrxracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrxracing &raquo;</TD></TR><TR><TD CLASS="quote">Are all del sol's the 1.6 vtec?</TD></TR></TABLE>
S (base model) is non-VTEC. In 92-95 it was a 1.5L engine. In 96-97 I think they bumped it to 1.6L.
Si is SOHC VTEC, 1.6L.
VTEC is DOHC VTEC, B16A3/B16A2 1.6L.
Old Sep 20, 2006 | 08:42 AM
Default Re: (MonkeyBoy668)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyBoy668 &raquo;</TD></TR><TR><TD CLASS="quote">
VTEC is DOHC VTEC, B16A3/B16A2 1.6L.</TD></TR></TABLE>
Dang beat me to it. All correct info. Check TeamdelSol For more info on everything related to the Sol.
Old Sep 20, 2006 | 08:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrxracing &raquo;</TD></TR><TR><TD CLASS="quote">What kinda rebuild are you speaking of? thanks</TD></TR></TABLE>
As far as a rebuild of a Single cam for boost. I would go with Pistions, Rods, Block Gaurd, P&P head (optional), best headgasket you can buy, Valves, Springs, Retainers and a Cam, Dont forget to tune it after the turbo. Doing this is often cheaper and simpler than a swap and can provide HUGE power numbers 350whp+ on pump gas easy. you just got to do it right and plan your build before you start. Good luck
Old Sep 20, 2006 | 10:41 AM
mrxracing's Avatar
Great! this should get me started for now, thanks for the info fellas!!
Old Sep 20, 2006 | 11:58 AM
MI KENT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowSlow93Sol &raquo;</TD></TR><TR><TD CLASS="quote">As far as a rebuild of a Single cam for boost. I would go with Pistions, Rods, Block Gaurd, P&P head (optional), best headgasket you can buy, Valves, Springs, Retainers and a Cam, Dont forget to tune it after the turbo. Doing this is often cheaper and simpler than a swap and can provide HUGE power numbers 350whp+ on pump gas easy. you just got to do it right and plan your build before you start. Good luck </TD></TR></TABLE>
save your money don't buy the block guard.
x.l.r.8
Oct 25, 2016 03:10 PM
leillox88
16
Nov 7, 2014 11:22 AM
mmunozem1
Jan 26, 2014 02:56 PM
jessej1111
Aug 19, 2013 06:34 AM
