Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
WTF window lock problem.
Old Sep 20, 2006 | 03:56 AM
Demonis's Avatar
Default WTF window lock problem.
I duno if anyone else noticed this, but when you turn on window lock, the driver cant roll down any windows? Every car i have ever been in, window lock just disables any other doors controls of windows.... This isnt just my car is it?
Old Sep 20, 2006 | 04:14 AM
-K-'s Avatar
-K-
Default Re: WTF window lock problem. (Demonis)
Nope, it's not just you. Window lock definitely locks ALL the window controls including the driver's in my car, too.
Old Sep 20, 2006 | 06:27 AM
Demonis's Avatar
seems to defeat the purpose to me.
Old Sep 20, 2006 | 06:39 AM
-K-'s Avatar
-K-
Default Re: (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">seems to defeat the purpose to me.</TD></TR></TABLE>
Agreed.
Old Sep 20, 2006 | 09:07 AM
gus738's Avatar
Default Re: (-K-)
same here window lock locks all of my windows too , EX
Old Sep 21, 2006 | 02:39 AM
Demonis's Avatar
this is retarded, if a child rolls down a window, and you window lock, how are you supposed to roll it back up? Honda made a mistake on this one...
Old Sep 21, 2006 | 09:12 AM
dcmix5's Avatar
I'm confused...
When I lock my window lock, my driver's side window still rolls down.
Old Sep 22, 2006 | 03:30 AM
Demonis's Avatar
I hope you're being an idiot liar, because if it does, im going to honda ASAP. Also, what model/trim are you driving? Year?
Old Sep 22, 2006 | 09:36 AM
dcmix5's Avatar
Yes, I am lying, and I am an idiot. I hear it is a good way to make friends.
I have a 2006 Si.
Here are my steps:
1. Window lock is up, with orange showing near the bottom of the button to indicate this.
2. Roll both windows down and up.
3. Press window lock button down.
4. Push both window buttons down and only the drivers side works.
That's it, and if necessary I will make a video with my digital camera to prove it.
Old Sep 23, 2006 | 02:58 AM
Demonis's Avatar
Even if that works, its kinda moronic to have to do that ritual just for it to work.... you cant do that when your child is attempting to crawl out a window at 60mph
Old Sep 23, 2006 | 03:38 AM
SennaPerfected's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">Even if that works, its kinda moronic to have to do that ritual just for it to work.... you cant do that when your child is attempting to crawl out a window at 60mph</TD></TR></TABLE>
Demonis: The steps dcmix5 outlined is exactly what the window lock does, and has been doing for years; and that is, once the button is pressed down, the passenger side window is disabled (until the button is released to resume normal function), but the drivers side window still remains fully functional.
Pressing a single button down to lock the passenger window is hardly moronic. Actually, it's effective, simple, yet so complicated. The real issue here is, a child roaming around the car "attempting to crawl out a window at 60mph".
Also, you may or may not be aware, but... Most, if not all of us here on Honda-Tech are here to learn, assist, and if necessary, lend a helping hand. With that said, responses tend to be elicited in the manner they are presented. Please try to refrain from responses like the one towards dcmix5.
Old Sep 23, 2006 | 03:40 AM
BLU BY U's Avatar
Default Re: (dcmix5)
mine locks the passenger window but still allows me to use the driver side.
Old Sep 23, 2006 | 04:50 AM
dpao6's Avatar
Default Re: WTF window lock problem. (-K-)
Weird, my driver side still rolls down too with the window lock activated. I doubt it's because it's a DX cuz the guy above me with the Si is the same, i would assume the window lock mechanism/relay is a mass produced part used on all models of current Civics.
Old Sep 23, 2006 | 06:02 AM
n3twrkm4n's Avatar
If the window is up like it should be with a child in the seat, then the window will be locked up. Without you having to worry about rolling it up. On the other hand if you lock the windows when the window is down with a child in the back, it defeats the purpose of the window lock feature.
Old Sep 23, 2006 | 07:29 AM
Demonis's Avatar
Okay, first of all, by 'moronic' i wasnt referring to HIM, i was referring to the "roll both windows down, then up, then use the window lock and the drivers window will roll down." process.
Secondly, I used the kid falling out the window as an example, because this has happened in the past, THUS window locks were born.
Lastly, mine were up... pushed the window lock, and niether window would work....
Better?
Old Sep 23, 2006 | 04:15 PM
haby red fg2's Avatar
mine just locks the passenger window and did the same thing on my 97 ex the driver side works no matter if the lock is on or off
Old Sep 23, 2006 | 06:53 PM
eL's Avatar
eL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcmix5 &raquo;</TD></TR><TR><TD CLASS="quote">I'm confused...
When I lock my window lock, my driver's side window still rolls down.</TD></TR></TABLE>
Same here.
Old Sep 24, 2006 | 08:22 AM
Demonis's Avatar
*sigh* was I that misunderstood?
Window lock locks my window, DRIVER side...
Old Sep 24, 2006 | 02:46 PM
Striker_1818's Avatar
Sedan(all trims)
Window lock - it locks all windows, aside from driver's side, to keep them from rolling up or down even on the master control which is located on the driver's side door panel.
Coupes and Si:
Window Lock - same as above but with the difference it locks the passanger side since it has only 2 doors. It does NOT lock the driver's side on any trim...
Overall, With window lock on, driver's window will work regardless. Passanger(s) window(s) will not work.
If yours works different than mentioned above, take it to your dealership and have it(them) fixed. And stop bitching each other out
Old Sep 25, 2006 | 06:04 AM
dcmix5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">*sigh* was I that misunderstood?
Window lock locks my window, DRIVER side... </TD></TR></TABLE>
No, I don't think so.
If you read what I posted, you can clearly see that I understand that your window lock will lock your driver's side window.
I posted that it DOESN'T lock mine. My driver's side window works at all times, with the window lock on or off, as intended.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">Okay, first of all, by 'moronic' i wasnt referring to HIM, i was referring to the "roll both windows down, then up, then use the window lock and the drivers window will roll down." process.
Better?
You don't need a "ritual" to lock the windows, so I think you are misundertanding what I did there. I was attempting to illustrate the process in order to prove that my window lock did not affect my driver's window.
All you need to do is press the window lock button, and that is it. One press, and my passenger window is locked. Period.
deerman2701
Nov 27, 2007 05:59 AM
fongyz22
Honda Civic (2001 - 2005)
Oct 31, 2007 12:54 PM
4Dinsaneb16
Mar 20, 2007 01:30 PM
george34
Sep 27, 2006 07:23 PM
.jacob
11
Mar 3, 2003 05:25 AM
