Is a tapered throttlebody important?
What is the difference between no tapered and tapered throttlebody ? I need a 65mm throttlebody to fit with my edelbrock intake manifold and wanna know what the difference is>?
stock TB's have the taper...
if your looking for a replacement its hard to beat this https://honda-tech.com/zerothread?id=1624626
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">stock TB's have the taper...
if your looking for a replacement its hard to beat this https://honda-tech.com/zerothread?id=1624626</TD></TR></TABLE>
thats what im planning
i think its 3" to 68mm butterfly
is that a good taper?
I have a 69mm-> 65mm on my D series. I'm pleased with it.
It's essentially creating a venturi which will in essence speed of velocity. It also helps that most of these are actually 3" which is what most intakes are....
Nathan
Nathan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 »</TD></TR><TR><TD CLASS="quote">maxbore has a 5mm taper, 70mm out 65 butterfly
is more taper the better?</TD></TR></TABLE>
are you sure you can bore a stock TB to 70mm at the opening? but im wondering the same question on the taper also...but he power is tapered, correct??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">pretty sure the 68mm version tapers to 70 but i dunno for a fact.</TD></TR></TABLE>
ehh....the old reverse taper trick huh??
tygsr
Jan 10, 2004 03:21 PM
