92 civic ignition tumbler install questions
Old Sep 19, 2006 | 06:51 PM
94hatchvx's Avatar
Default 92 civic ignition tumbler install questions
ok. i lost my keys so i bought a new ignition tumbler and door locks for my car. i finally got them today and i dont know how to get the old tumbler out to put the new one in. i know some one has done this. does anyone have pics or wut to unscrew or unclip? thanx
NJcoupe's Avatar
Default Re: 92 civic ignition tumbler install questions (94hatchvx)
You have to use a punch and a drill bit to drill out the old column lock.
Old Sep 19, 2006 | 07:07 PM
94hatchvx's Avatar
Default Re: 92 civic ignition tumbler install questions (dxcoupe.)
does anyone have a DIY or write up with pictures on how to do this?
Old Sep 19, 2006 | 07:23 PM
NJcoupe's Avatar
Get a Helms or a regular repair manual from your local auto parts store.
Old Sep 19, 2006 | 07:26 PM
94hatchvx's Avatar
i dont have any money for another week. im just trying to see if anyone has done a write up with pictures.
Old Sep 20, 2006 | 05:24 PM
94hatchvx's Avatar
bump for help
Old Sep 20, 2006 | 06:34 PM
lightcrx's Avatar
did you get the complete lock assy? or just the tumbler? if you just got the tumbler then you have to have someone(locksmith) take the old one out, you have to turn the key inorder to take the tumbler out..
-joseph
Old Sep 20, 2006 | 06:44 PM
94hatchvx's Avatar
Default Re: (lightcrx)
i just got the tumbler. i bought the tumbler because i lost my keys and didnt have a spare. is there any other way to get the tumbler out and the new one in?
Old Sep 20, 2006 | 06:52 PM
cxSHOE's Avatar
what are all these people talking about..... completely wrong information...
this is what you are suppose to do..there are two ways to have automobile keys made.
first off why did you buy new key cylinders? if you look on your new tumblers you will see 4 numbers on it... that is your key code. so if you just took out any of the key cylinders from the door, or the trunk or etc... you have just gotten a new key made? or just going to the dealership with your vin# a new key can be made aswell????
well anyway. you will need your old key, put it in the ignition, turn it once. then at the top of the actual ignition there is a small hole (size of a paperclip diameter) you push that down and you then pull the key out which then pulls the old key cylinder out. installation is reverse.
if i were you, as long as you didnt open the bags return it then get a new key using your vin# and we can lock this thread. good luck
Old Sep 20, 2006 | 06:55 PM
dpaton's Avatar
Dude, any Honda dealership can cut you a new key with a copy of the title and your VIN. No need to buy new locks.
Old Sep 20, 2006 | 06:56 PM
cxSHOE's Avatar
if your not sure where it is you can ask this guy, who i also showed how to do it..
https://honda-tech.com/zerothread?id=1756557
Old Sep 20, 2006 | 06:57 PM
94hatchvx's Avatar
Default Re: 92 civic ignition tumbler install questions (cxSHOE)
did you not read what i posted before? i dont have the keys to my car. it was stolen before and the door locks are not matched to the vin code. also the ignition is not the one that matches the vin code.
Old Sep 20, 2006 | 06:59 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">did you not read what i posted before? . </TD></TR></TABLE>
no....
your only option is to get a dent puller and pull it out, then insert the new one as i wrote above.
Old Sep 20, 2006 | 07:13 PM
94hatchvx's Avatar
so thats all you do is pull it out? theres no screws or anything? i just pull the expletive out of it and hope it comes out?
Old Sep 20, 2006 | 07:34 PM
94hatchvx's Avatar
bump
Old Sep 21, 2006 | 06:38 AM
lightcrx's Avatar
take the ignition off and take it to a lock smith, he'll get it out. probly wont charge much either, the dent puller wont work all it will do is mess up the cyl or brake the part you still need....
if you need pic's lmk
-joseph
Old Sep 21, 2006 | 11:30 AM
dpaton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">the door locks are not matched to the vin code. also the ignition is not the one that matches the vin code. </TD></TR></TABLE>
That's new information that would have been helpful. Time to call a locksmith to swap the tumbler or get out the big hammer....
Old Sep 21, 2006 | 11:34 AM
lightcrx's Avatar
id say get the rest of the ignition assy because without a locksmith or a master key your not going to get the tumbler out..
-joseph
Old Sep 24, 2006 | 03:51 PM
94hatchvx's Avatar
thanks for all the info. can you post up some picks on how to take out the ignition so i can take it to the locksmith? this is my daily driver and i need to finish rebuilding the motor and get it running again asap. but i cant towe it cause the wheel locks. you know. anywayz, thanks for the help. cant wait for the picks
Old Sep 24, 2006 | 04:16 PM
lightcrx's Avatar
Default Re: (94hatchvx)
take the plastic's off around the ignition colume and u'll follow the assy and you'll see tw bolts holding it togather, but they have no heads. what you need to do is take a flat screw driver or chisle and hit it to make the bolts turn counter clockwise thats it after they spin a few times you can unscrew them by hand. also dont for get to unscrew the "white ball" theres 2 screws inback of the assy with the ign wires on it..
-joseph
Old Sep 25, 2006 | 08:30 AM
94hatchvx's Avatar
do you have pictures? im not really understanding it.
Old Sep 25, 2006 | 08:57 AM
lightcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">take the plastic's off around the ignition column and u'll follow the assy and you'll see tw bolts( 2 ) holding it together, but they have no heads. what you need to do is take a flat screw driver or chisel and hit it to make the bolts turn counter clockwise thats it after they spin a few times you can unscrew them by hand. also dont for get to unscrew the "white ball"( 1 ) theres 2 screws inback of the assy with the ign wires on it..
-joseph</TD></TR></TABLE>
i dont mind helping people out but when i explain something this easy you gotta help me out.... im not going to come over and do it for you..... you gotta visualize the goal
-joseph
Old Sep 25, 2006 | 09:20 AM
94hatchvx's Avatar
thanks for all the help. im just more of a visual learner. thanks for putting up with the stupidity. lol. im gonna go do it know.
skunk_ape311
Honda Civic (2001 - 2005)
Mar 18, 2018 12:12 PM
.David
11
Feb 17, 2006 09:14 AM
JamesV
Dec 25, 2005 09:25 PM
fluke702
Apr 13, 2005 02:06 PM
Team 4R
77
Aug 22, 2004 09:13 AM
