Changing cams in a B16
Old Sep 19, 2006 | 03:15 PM
crxpwr1's Avatar
Default Changing cams in a B16
How do you know when your at tdc...and which is the #1 cylinder
thank you in advance
Old Sep 19, 2006 | 03:28 PM
eda6's Avatar
Default Re: Changing cams in a B16 (crxpwr1)
The cam gears have the word "up" etched on them. they will be facing up. there's another set of marks (3 oclock on the ex cam, 9 oclock on in cam) etched on the cam gears that will be looking at each other and will be parallel with the head when you're at tdc.
#1 cylinder is next to the timing belt.
Old Sep 19, 2006 | 03:29 PM
crxpwr1's Avatar
Default Re: Changing cams in a B16 (eda6)
thanks man much appreciated
Old Sep 19, 2006 | 03:32 PM
eda6's Avatar
you'll need to adjust valve lash afterwards. I like to keep it simple and go with .007" on both
there's some nice write-ups in the itr faq thread.
Old Sep 19, 2006 | 03:33 PM
Mugencrxsir1's Avatar
Default Re: (eda6)
http://i75.photobucket.com/alb...r.jpg
Here's a pic a got off HT, plan and simple.
Old Sep 19, 2006 | 03:54 PM
crxpwr1's Avatar
Default Re: (Mugencrxsir1)
Do i still have to adjust the valve lash if Im just putting the 2nd gen cams into a 1st gen b16
Old Sep 19, 2006 | 03:57 PM
Default Re: (crxpwr1)
I would atleast still check the valve lash.
Old Sep 19, 2006 | 04:51 PM
crxpwr1's Avatar
where can I get a angler feeler gauges
Old Sep 19, 2006 | 06:31 PM
green91's Avatar
anywhere, auto zone, advaned, sears, snap-on
Old Sep 20, 2006 | 12:07 AM
91SiZ6's Avatar
Please buy a repair manual while you're buying your new tools.
Mugencrxsir1
Dec 16, 2010 01:11 PM
SolAssassin
21
Oct 14, 2008 10:26 AM
Takumi Fujiwara
Jan 18, 2006 09:49 PM
HamiltonRex
May 3, 2004 07:04 PM
