need help on a swap
actually...
Isn't the VX a Vtec efficiency motor? this may not be as strait forward as everyone is claiming. You will not need to ust the wires that go to the vtec selonoid and you may have to make some wires longer or shorter for everything to plug in. If you have minimal mechanical experience you should be able to figure it out.
I have found in my experience that nobody knows what the **** they are talking about and the best bet is just to figure it out yourself.
If you have a 95 LS with a 95 LS engine harness on it, and a LS ECU, then you just drop the engine in, plug the 95 LS engine harness into your 92VX chassis harness, plug the 95LS ECU into that and you're good to go.
