What ECU is this?
Hello,
I have a B16A2 (Which is OBD II I believe) Swap in my CRX, here are some photos of my ECU:
Is this an OBD II to OBD I conversion harness going into a OBD I ECU?
Also if I buy a chipped ECU, I should be able to just hook it up an go right?
Well I know VTEC doesn't totally engage until 6k RPMs and the rev limiter is at 8k. I checked the ECU and it's blank on both sides, I haven't disconnected it to see the back, I thought you would be able to tell based on the plugs going into it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2tegsown »</TD></TR><TR><TD CLASS="quote">Well I know VTEC doesn't totally engage until 6k RPMs and the rev limiter is at 8k. I checked the ECU and it's blank on both sides, I haven't disconnected it to see the back, I thought you would be able to tell based on the plugs going into it.</TD></TR></TABLE>
If you remoce the top ecu cover, there will be another sticker with the ecu code written in the middle telling you what model it is.
