How did you wire VTEC to the ecu?
Old Sep 19, 2006 | 12:57 AM
Eyal 951's Avatar
Default How did you wire VTEC to the ecu?
You need to source pins for the clip somehow don't you, or is there another way? I need to do this befoire thursday, when my car gets dyno tuned. Any ideas how I can get it done quickly, oir just continue searching for an ecu clip or harness. (BTW, if any of you socal people have something, I'll buy it right away!)
Old Sep 19, 2006 | 01:03 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: How did you wire VTEC to the ecu? (Eyal 951)
what kind of car is it?
Old Sep 19, 2006 | 09:01 AM
Eyal 951's Avatar
Default Re: How did you wire VTEC to the ecu? (wrx-killer-Sti eater)
95 civic hatch, its in the sig. its SOHC Vtec.
Old Sep 19, 2006 | 09:08 AM
Eyal 951's Avatar
Default Re: How did you wire VTEC to the ecu? (JJDrivesAJazz)
thats only for 92 civics.
Old Sep 19, 2006 | 09:59 AM
sol2hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJDrivesAJazz &raquo;</TD></TR><TR><TD CLASS="quote">you should be pre-wired for vtec already if it's a 92-95 hatch</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 &raquo;</TD></TR><TR><TD CLASS="quote">thats only for 92 civics.</TD></TR></TABLE>
correct. my 93 hatch was not wired. I went to the junkyard, and just asked for the pins, then attached those to my own wires and wired it up. Junkyard should just give you them, they are not hard to come by
Edit: you only have to run two wires, it is very easy, there should be a FAQ at the top about it
Old Jan 13, 2007 | 09:45 AM
WHAT TEH's Avatar
werd. and tha vtec wires were only for tha ECU (pigtail) side.
_taF
Old Feb 8, 2007 | 08:21 AM
sled's Avatar
Default Re: How did you wire VTEC to the ecu? (tallazzFilipino)
i was wondering if thats just in the cx model or in dx also in 92?
Old Feb 8, 2007 | 08:24 AM
Luserkid's Avatar
Default Re: How did you wire VTEC to the ecu? (sled)
I usually go to junkyards and pick up as many ecu connectors as i can find just because of this. Sadly theres no other way around it. You might be lucky and try a hole in the wall electrical store with one of the ecu connectors and ask if they could find you a set. If they can you hit gold and make sure to let me know
smaxnz
Engine Management and Tuning
Aug 31, 2008 10:01 AM
JDM_Frijoles
Aug 24, 2006 10:50 PM
92hatch420
10
Jan 22, 2006 08:15 AM
GetawayInMoscow
May 9, 2005 08:49 AM
AzntaggeR
Feb 21, 2004 01:06 AM
