help with b16a2
Old Sep 18, 2006 | 10:40 PM
robert_v's Avatar
Default help with b16a2
i just swapped a b16a2 with ctr pistons in my hb and it starts up fine but backfires after 15 minutes. not only that, my response is really slow, meaning i gun the car and the car does not pick up at all. its really slow (you can run and beat me) does any one have an idea what can be wrong? i searched but could come up with a conclusion.
Old Sep 18, 2006 | 10:45 PM
Ruben19's Avatar
check your timing
should be at 16 degree
Old Sep 18, 2006 | 10:56 PM
fmrprojects's Avatar
Default Re: (Ruben19)
dudde if your car is not running right, you are not sippose to full throttle it. check the tps sensor.
Old Sep 18, 2006 | 11:01 PM
robert_v's Avatar
timing is at 16 degrees. i used both types of timing gun (digital and manual)
Old Sep 19, 2006 | 12:27 AM
Frozen E's Avatar
H-T White Ops
sounds stupid, but are your plug wires right?
Old Sep 19, 2006 | 11:22 AM
robert_v's Avatar
Default Re: (IslandSi)
everything is correct, its just not accelerating
Old Sep 19, 2006 | 12:04 PM
ziich2's Avatar
Default Re: help with b16a2 (robert_v)
Check to see if you're throwing any codes and make sure all your sensors are plugged in correctly. Is your VTEC engaging? Check ignition timing and TPS sensor.
Old Sep 19, 2006 | 12:44 PM
SkoundrelUSA's Avatar
cute little bastard
wouldn't you lean out with that much compression on a stock map?
Old Sep 21, 2006 | 01:01 AM
robert_v's Avatar
Default Re: help with b16a2 (ziich2)
vtec engages but still no pull. the only sensor not plugged in is the crank pulley sensor, but i'm using a 97 civic ex harness but have a pigtail and am now using a chipped p28 and theres no code. i dont have a obd2 ecu to run with. the sanner wont pick up the chipped ecu. (gynesis scanner)
hondaZvic
Jul 3, 2008 05:05 AM
dean2
Dec 27, 2006 11:21 AM
stivic
Oct 23, 2004 04:23 AM
iwouldHITit
13
Apr 20, 2003 08:24 PM
