Ignition Timing
Old Sep 18, 2006 | 08:36 PM
JdMhEaD's Avatar
Default Ignition Timing
Going to play with the ignition timing some tomorrow. should i keep it in the range of 15-18 degrees?
Mods are DC header, Short ram intake, lightweight FW, and a test pipe.
Old Sep 18, 2006 | 08:55 PM
92TypeR's Avatar
FSAE
Default Re: Ignition Timing (racefan11)
15-16 will give you the most peak power, 17-18 will give you more power in the low-mid revvs.
Old Sep 18, 2006 | 10:09 PM
mtber's Avatar
The answer to your question really depends on what ecu you are running.
Changing your base ignition timing from 16 deg btdc at 800 rpms to 18 deg btdc at 800 rpms will change your whole ignition map's values.
I would honestly recommend leaving your ignition timing at 16.5 deg btdc (red line on crank pulley) & making the adjustments via a eprom editor using a chipped ecu such as crome etc.
For more info read http://phearable.net/tech/efibeginnerguide.html
Old Sep 18, 2006 | 10:34 PM
JdMhEaD's Avatar
Default Re: Ignition Timing (mtber)
I am running a chipped P28 tuned with hondata s300
elprovos
Engine Management and Tuning
Feb 10, 2011 10:35 AM
I CRX I
Jan 30, 2009 07:11 AM
jdmb16ef8
10
May 4, 2008 04:47 AM
4dooritr
Aug 8, 2004 06:56 PM
Jockobo
Sep 21, 2002 04:42 AM
