b20vtec pcv valve
im curently building a b20vtec and i was woundering since the b16 pcv valve goes to the black box on the back of the block how i hook up my pcv valve thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 »</TD></TR><TR><TD CLASS="quote">you either run none or make a custom vacuum setup on the valve cover</TD></TR></TABLE>
theres more options then that! on the back the block is two 14mm hex caps. you take those out and put the h22a barbed fittings in and run them setup with a catchcan like endyns kit.
its cool thanks i talked to a friend tonight and he convinced me to just run the pcv valve to the intake manifold and like a catch can just run a line out of the other side of the pcv valve straight down under the car and let it drain any oil its like a catch can with the world as the biggest catch can ever has anyone else just ran this set up a line to the pcv valve from the manifold and then just let it hang??
a1320honda
Jun 30, 2007 09:22 PM
93egallmotor
Apr 21, 2007 01:45 PM
