Questions on getting head ported and polished
Old Apr 30, 2002 | 09:48 AM
onyx00's Avatar
Default Questions on getting head ported and polished
Couple questions:
1.) Know abot Portflow, but who else would people recommend. What should I expect to pay for a quality job?
2.) I am assuming I need to take the head off and send to them. In doing so, do I need to take everytihng out of the head, i.e. cams, valves, etc.
3.) How much of a performance increase should I expect with my current mods (header, intake, cat., V-AFC).
4.) Anything else I should consider?
Old Apr 30, 2002 | 10:40 AM
sgT's Avatar
sgT
Default Re: Questions on getting head ported and polished (onyx00)
1. Portflow is the way to go. his rate is 900-950 if i remember correctly
2. you can just remove the cams/caps/spray bars and send as is
3. expect a good amount of gain in midrange, maybe a little up top
4. things to consider depends on what your ultimate goal is
Old Apr 30, 2002 | 10:47 AM
Toda Party's Avatar
Default Re: Questions on getting head ported and polished (sgT)
What is the purpose of using oversize valves? I would imagine just a better rate of flow? pros/cons?
Old Apr 30, 2002 | 11:09 AM
sgT's Avatar
sgT
Default Re: Questions on getting head ported and polished (Toda Party)
good for use in over bored(ie 83+mm) but no real use for stock bore
cant use aggressive cams due to valve-valve clearance issues
Old Apr 30, 2002 | 11:12 AM
onyx00's Avatar
I think you are right with the flow. Get fresh air in faster and get exhaust gases out faster. Not sure beyond that.
Old Apr 30, 2002 | 11:18 AM
Toda Party's Avatar
gotcha
Old Apr 30, 2002 | 11:38 AM
Mike K's Avatar
Exactly what Sakai said. Big meaty midrange, just a little on top.
Real smooth curve.
I had Topspeed do my head. I think he gets $700-750.00, and his turnaround time is 2 weeks or so. Highly recommended.
Sorry for the shitty scan.
Before and after ported head.
B18C5, stock cams, stock ECU, stock exhaust, AEM intake, V-AFC, gears, DC JDM
Head was milled 12 thou for 11:1 compression.
Old Apr 30, 2002 | 12:05 PM
Big Teggie's Avatar
Default Re: Questions on getting head ported and polished (Mike K)
Whats the email or number for topspeed?
Thanks
Old Apr 30, 2002 | 12:28 PM
Mike K's Avatar
Default Re: Questions on getting head ported and polished (Big Teggie)
j.n.holcombe@worldnet.att.net
or
(239)514-7008
Ask for Josh
Old Apr 30, 2002 | 12:34 PM
nerdish's Avatar
Where is Topspeed located?
Old May 1, 2002 | 08:53 AM
Big Teggie's Avatar
Default Re: Questions on getting head ported and polished (nerdish)
I think in florida.
djviet2000
Nov 26, 2010 02:21 AM
H-allmotorda9
17
Feb 6, 2010 07:40 PM
Boostedb20EH2
Mar 25, 2007 05:56 PM
CRX 2.0V-T
Feb 8, 2007 12:32 PM
1hotintegra
Jun 9, 2003 07:51 AM
