HELP! oil pressure sensor and bad idle
Old Sep 17, 2006 | 11:53 PM
ziich2's Avatar
Default HELP! oil pressure sensor and bad idle
Actually I doubt this has anything to do with my fluctuating idle, but I was searching for vaccuum leaks and I found that I was missing the plug that goes to this. (oil pressure sensor?)
view from the back of the motor (obviously)
The wire is cut or stripped, missing the plug (you know, the one with the black rubber boot over it). Where can I get another one of these?
Old Sep 17, 2006 | 11:56 PM
duggy's Avatar
You can find it from a trash harness that has been cut up or something. You can't buy it from the dealership.
Old Sep 17, 2006 | 11:58 PM
ziich2's Avatar
Default Re: (duggy)
Technically all I need to do is make a secure metal-to-metal connection with that right? So couldn't I fab something from an autoparts store, or i was thinking about using an audio connector. Stupid idea?
...or WTB: one of those
Old Sep 18, 2006 | 08:03 PM
ziich2's Avatar
Default Re: (ziich2)
anyone know what this does?
Old Sep 18, 2006 | 08:08 PM
turbociviccoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ziich2 &raquo;</TD></TR><TR><TD CLASS="quote">Technically all I need to do is make a secure metal-to-metal connection with that right? So couldn't I fab something from an autoparts store, or i was thinking about using an audio connector. Stupid idea?
...or WTB: one of those</TD></TR></TABLE>
just go to a junk yard and cut one off. but i have used a makeshift plug before.
Old Sep 18, 2006 | 08:15 PM
nighttrain33's Avatar
The plug is just one wire and is only used for a dummy light. If you wanted to get an accurate reading of the oil pressure just forget about the sensor, and hook up an oil pressure gauge straight to the back of the block. But then I guess you would get "the light."
-Shane
Old Sep 18, 2006 | 08:44 PM
onepointsixvtecturbo's Avatar
I have that oil press. Sensor its greddy one lmk if u want it pls email at spoon95eg@tmail.com or aim tjefferson216
Old Sep 18, 2006 | 10:03 PM
teknoracing's Avatar
Default Re: (onepointsixvtecturbo)
I think he's concerned that the light will come on, not on actual reading right now. I would try to find one at the junk yard or make a makeshift plug.
Old Sep 21, 2006 | 01:39 PM
ziich2's Avatar
Default Re: (teknoracing)
well what i was actually concerned about is whether missing this plug would affect the car's peformance in any way. Cause, right now it runs like crap and I'm trying to find a solution.
Old Sep 23, 2006 | 08:51 AM
ziich2's Avatar
ghetto rigged a plug by putting an audio cap that i got from an auto store on there and the other end plugs right into the sensor.
Rukusmasta2
May 5, 2008 03:30 PM
96_RHD_EK
Feb 6, 2008 06:32 AM
sasinorm01
Nov 21, 2006 07:26 PM
integra-modder
Jul 16, 2004 06:44 PM
Audipwr1
Jul 18, 2003 02:37 PM
